Old 10-04-2018, 10:38 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Need turbo size help
So I'm selling my twin turbo kit and going big single.
The engine is a 6.0 iron stock bore, stock stroke, ls3 heads, sheet metal intake. Going to be on e85 and making 1000whp.
Was looking at the s475 with 1.32ar but not sure if that's a good size. Car is also going auto with a th400 but unsure of the stall size yet.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 10-04-2018, 02:52 PM   #2
bayarea408
bayarea408's Avatar
Drives: T
If you were at 1000, im assuming going to a big single you will be looking for gains. I have seen S480 do mid 1100's on a 6.0, although you may have to go T6 frame. S475 might be close to where you were at with twins, alot depends on the housing you use. For PTE 88/47 is a 4" dump on a T4 flange, someone on here did 900+ wheel recently on a stock block ls3.
bayarea408 is offline   Reply With Quote
Old 10-04-2018, 04:08 PM   #3
Punisher_ATX
Drives: 2010 SS
Personally shooting for 1000+ myself and have a Billet s482 going on Id be looking something in that ballpark that flows 135+lbs S480-S484 range
Punisher_ATX is offline   Reply With Quote
Old 10-06-2018, 08:21 AM   #4
907 chad
Drives: 2010 2SS RS
I went with the cast wheel s480 T-6 96mm 1.1ar and v2 race cover from lil John’s Motorsport. On my bone stock l99 I start building boost at 1900rpm. For me I wouldn’t want the s475 or the t4. I’m very happy with what I got. This turbo on a 6.0 with lower compression will take a little longer to spool but not much.
907 chad is offline   Reply With Quote
Old 10-07-2018, 06:53 PM   #5
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Your twins won't support 1000rwhp, or is there a different reason for going to big single?
RealQuick is offline   Reply With Quote
