Old 10-08-2018, 05:02 PM   #1
ca_z28
Drives: 2014 Z/28
Headlights Always On
Whenever I start my '14 Z/28, the headlights come on and stay on. No matter what time of day it is, the automatic headlights come on. I have to turn off automatic headlights every time I start the car. Has anyone run across this before? Does anyone know where the headlight sensor is that tells the lights to come on? I'm thinking it might be blocked or not working.
ca_z28 is offline   Reply With Quote
Old 10-08-2018, 05:26 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
The sensor in a V6 Camaro (I assume it's the same for the Z28) is in the front/centre vent of the dash, near the windshield - the sensor is in the same piece/unit that contains the red light that lights when the alarm is on. Kind of a pain to get to.
There is a connector with three wires: white, black and grey; the grey is for the red light; white or black is for the light sensor, and the other is the negative. If your lights are on all the time then you maybe you're getting a high resistance between white and black. Not entirely sure how to test this off hand...
FYI, putting a low-resistance resistor (I used 3k ohm) in the connector from white to black will make the sensor think it's always light out, so your lights won't come on when you go under an underpass or into your garage or stupid things like that. You will also lose the red alarm light this way, however.
KillboyPowerhead is offline   Reply With Quote
Old 10-08-2018, 05:37 PM   #3
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
The Z/28 is programed to work that way, no DRL lights in the lower bumper, and non in the headlights so there all ways on.
Old 10-08-2018, 05:50 PM   #4
MrRaZ28
@MrRaZ28
MrRaZ28's Avatar
Drives: 2014 Z28 #80
^^ what he said. They don't turn off unless you make them turn off. It's a safety feature.
MrRaZ28 is offline   Reply With Quote
Old 10-08-2018, 07:38 PM   #5
ca_z28
Drives: 2014 Z/28
So my headlights are DRL's, never thought about that. Not crazy about it but it is what it is. Thanks for the info.
Old 10-09-2018, 02:26 AM   #6
pat_t
Drives: .
I also found this a bit irritating. But I found there is another 'work-around'.
If you flip to the sidelight position then sidelights will be always on, headlights off (if you've seen my car you'll know I modified the sidelights to be a LED DRLs, but that's not important here).
If you just leave it in that position you will get a beeping noise on shutdown warning you that you've left the lights on.. but if you just ignore the warning and shut and lock the car, the lights will turn off after a few minutes - Chevy must have put them on a timer to prevent battery drain.
pat_t is offline   Reply With Quote
Old 10-09-2018, 01:47 PM   #7
ca_z28
Drives: 2014 Z/28
I'll check that out. Thanks
Old 10-10-2018, 11:34 AM   #8
2SSRS@Gen5diy
Hi pat, you need to let him know this will turn on all running lights, the tails will come on to, as a running light, this may not do what he wants, best way to do what you want is to cut the power in the day time to the headlights, that is done with a harness.
Old 10-10-2018, 03:05 PM   #9
pat_t
Drives: .
Good point! It does depend what you want. I don't mind the rear running lights on
Old 10-12-2018, 09:22 AM   #10
MIKZ28
Drives: 2019 Camaro ZL1 2004 Pontiac GTO
What harness?
MIKZ28 is offline   Reply With Quote
Old 10-12-2018, 09:30 AM   #11
j o n
j o n's Avatar
Drives: 2015 Z/28 #0058
there's no DRL fuse? Most cars have them
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's
- '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony
Sold:
- '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's
https://www.instagram.com/__jon__athan__/
j o n is offline   Reply With Quote
Old 10-12-2018, 11:50 AM   #12
ca_z28
Drives: 2014 Z/28
Thats a good question, is there a fuse just for the DRL's that would still let the lights come on at night? Seems like it would be the same fuse?
Old 10-12-2018, 01:33 PM   #13
2SSRS@Gen5diy
Originally Posted by MIKZ28 View Post
What harness?
The power comes over the headlights as we don't have independent DRL lights.
You have to move the power away and that is done with relays.
Old 10-12-2018, 08:10 PM   #14
MIKZ28
I found a quick fix for this. Just dissemble the light switch and remove or disable the spring. Then just leave the headlight switch in the off position.
