Old 10-09-2018, 09:08 PM   #1
ksungela
Drives: 2010 ss
rear axle spline dimensions
Does anyone know the spline dimensions on rear axle, inner end that goes into the inner CV joint? 2010-2012 Camaro SS manual trans. I need custom axles made so need to tell the manufacturer the specs.
ksungela is offline   Reply With Quote
Old 10-10-2018, 12:22 PM   #2
600hp-lpe
Drives: 2010
Upgraded cv joints come with new axles on both sides. you wouldn't want to upgrade the axle and not the CV as well.
most of the breakage with axles are the CV blowing apart.
600hp-lpe is offline   Reply With Quote
Old 10-10-2018, 01:20 PM   #3
ksungela
Drives: 2010 ss
thanks for the response. To explain more, I want to use a Camaro differential and C6 corvette suspension (and hubs), so need to buy camaro and corvette complete axles, take them apart and get new axle shafts to connect the camaro inner CV to the corvette outer CV. The other alternative is to shorten and cut the axle and respline one end to go into the camaro inner CV. Just talked to Dutchman who said they can do it even on hardened axles.
