Old 10-10-2018, 09:25 PM   #1
Sam94
Sam94's Avatar
Drives: 2015 Camaro 1SS RS
Have to remove my axle-back exhaust soon... Clamp question
The lease on my SS is soon coming to an end. I will be removing the Borla axle-back exhaust and re-installing the factory mufflers back on. Would I be able to use a good quality Band Clamp (butt joint) ? Was looking at this one made by Pypes at Summit.
2015 Camaro 1SS/RS Blue Velvet Metallic, L99, Airaid Intake Tube, Akebono Ceramic Brake Pads, Borla S-Type Axle Back, GM Strut Tower Brace, Range Device
Sam94 is offline   Reply With Quote
Old 10-10-2018, 10:43 PM   #2
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
You should be fine with that.
Talladega is offline   Reply With Quote
Old 10-12-2018, 08:28 PM   #3
Sam94
Sam94's Avatar
Old 10-15-2018, 09:23 PM   #4
Joecruiser
Joecruiser's Avatar
Drives: 2014 2-SSRS Slushbox
Thx Sam94....I just picked these Solo Performance axle back with J pipes from a member here to replace my Borlas. I was hoping I could install by clamping but it came with no clamps and the seller said it would have to be welded on.
Now your post gives me a possible no weld solution. I don't weld and taking it to a shop, in addition to costing $$$, would take hours of waiting. Cutting my Solos to butt up and clamping is doable.
https://www.camaro5.com/forums/showthread.php?t=532195
Joecruiser is offline   Reply With Quote
Old 10-15-2018, 09:55 PM   #5
Sam94
Sam94's Avatar
Glad to help Are you going to buy the one I posted or a similar type ? I won't be swapping mine for a couple of months, please let me know how they work out for you.
Old 10-15-2018, 11:54 PM   #6
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
BMW uses those on all their cars. They're super nice. You'll have no problems as long as you get the correct size and you install them properly.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 10-15-2018, 11:57 PM   #7
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Those Pypes clamps are bad ass!!!!! Work fantastic.
zz430camaro is offline   Reply With Quote
Old 10-18-2018, 09:49 PM   #8
Joecruiser
Joecruiser's Avatar
Originally Posted by Sam94 View Post
Glad to help Are you going to buy the one I posted or a similar type ? .
Already have Borlas. I bought the Solos J pipe. Ordered the clamps you posted in 2.5".
The Borlas are installed with a small single bolt clamp.
Previous owner had the Solos were welded on. I'll be grinding off the welds and hopefully those clamps will do the trick.
Old 12-04-2018, 07:07 AM   #9
Sam94
Sam94's Avatar
Just want to confirm before I order the Pypes clamps, the size I need is 2.5," correct ?
Old 12-05-2018, 10:09 AM   #10
600hp-lpe
Drives: 2010
yes - stock ss exhaust is 2.5".
the band clamps work great - borla uses them for the cat back exhaust up front. never had an issue with them - makes removing the exhaust easy.
600hp-lpe is offline   Reply With Quote
Old 12-05-2018, 10:12 AM   #11
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Stock system uses band clamps so you should be fine.
SSEssence is offline   Reply With Quote
Old 12-26-2018, 07:58 PM   #12
Sam94
Sam94's Avatar
Installed the stock exhaust today with the Pypes clamps. They are heavy duty and worked perfect ! Damn the car is quiet now lol
Old 12-29-2018, 10:47 PM   #13
myold88
myold88's Avatar
I've had the Solo J/Pipe axle backs on my SS for over 8 years now. I clamped them on new
and never had an issue. I wonder why anyone would weld the exhaust on? Just asking.
