Old 10-18-2018, 09:35 AM   #1
mmaattppllaayy
Drives: '10 Camaro 2SS
ZL1 Pump DW400 Swap
Has anyone swapped out the pump in a ZL1 module with the DW400 pump? Seems like a really great in between pump that could handle in the 800-900 range for fairly cheap.
mmaattppllaayy is offline   Reply With Quote
Old 10-18-2018, 10:49 PM   #2
Blakester
Drives: 2010 1ss
Are you talking about just doing a pump swap to a higher flow non gm pump but in the oem fuel bucket?
Blakester is offline   Reply With Quote
Old 10-19-2018, 09:10 AM   #3
mmaattppllaayy
Yes exactly.
Old 10-19-2018, 05:18 PM   #4
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Over the winter I plan to swap my V2 pumps for the AEM upgrades. Hopefully some larger injectors also.
Unavowed is offline   Reply With Quote
Old 10-19-2018, 06:19 PM   #5
mmaattppllaayy
I am really more concerned with swapping out the single pump in a zl1 bucket for the larger dw400 if anyone has done that or similar larger pump.
Old 10-19-2018, 11:18 PM   #6
Blakester
Drives: 2010 1ss
Ive been wondering how this would work too. Had my eye on the walbro hellcat 525 pump. Price looks super reasonable. But I figured with a stock fpcm or even an adm tuned zl1 fpcm wouldn't allow you to take full advantage of a aftermarket pump.
I am sure the company's that sell fuel systems for our cars could do something to make this work. But I am also sure that they make way more money off the super expensive 2 or 3 pump systems.
Old 10-21-2018, 08:54 PM   #7
eLeSthree
Drives: 2011 Camaro SS 6sp
Pretty sure someone tried this. Try a search?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 10-21-2018, 09:38 PM   #8
mmaattppllaayy
If you can find it post the link. I have searched quite a bit.
Old 10-22-2018, 04:41 AM   #9
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
I posted a thread about this before. It seems that there was the issue of having a PWM pump compatible with the FPCM and the FPCM being able to feed enough amps to the new pump or the wiring being up to it. The post was quite a while ago and the newer pumps have come a long way.
I recently dropped a ZL1 pump in my 2010 and was batting around the idea of using the old pump assy as donor to try swapping to a new larger pump.
The DW400 draws 16.5amps at 13.5volts - pretty sure that is higher than stock requirement.
https://www.deatschwerks.com/sites/w...ch%20Sheet.pdf
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 10-22-2018, 02:08 PM   #10
0331Marine
0331Marine's Avatar
Drives: 2012 SS/RS MN6
I'm running a CTSV pump with DW300 pumps with no issues.
0331Marine is offline   Reply With Quote
Old 10-22-2018, 02:57 PM   #11
eLeSthree
Do you run E85? About how much power has it been supporting?
I need a fuel system...
1158whp 1017wtq.
630whp 658wtq
Old 10-22-2018, 03:01 PM   #12
Punisher_ATX
Drives: 2010 SS
Just finished installing the Vaporworx System in my car. Was pretty simple and in an application with a single 450 and no boost reference it would be even easier i feel.
Punisher_ATX is offline   Reply With Quote
Old 10-22-2018, 03:36 PM   #13
mrimpala02
Drives: Black 2SS RS w/White Stripes
I have a CTS-V pump that I pulled a couple of months ago. I would like it to find a good home if anyone is interested.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 10-22-2018, 08:06 PM   #14
fleebag
fleebag's Avatar
Drives: Moneypit
I did same couple years ago, not e85 yet but twins with 127lb injectors, 55%dc.
Not sure if I'm gonna go bigger for e85
fleebag is offline   Reply With Quote
