Great White
Installed Hero tail lights. Got humming noise now
https://youtu.be/gh6mPBF4TUchttps://youtu.be/gh6mPBF4TUc
I just installed Hero tail lights and now I get noise from my speakers. Buzzing sound only on when lights turned on. Unplugged lights noise gone so definately lights. Didnt have noise with my stock lights. Any ideas? Already checked wires at harness. No pinched wires. My amp is not stock. Noise is annoying as #@!. Any help appreciated
![]() ![]() Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
No issues with my Hero tails and factory stereo. However I did try to hook up an amp/sub about 6 months ago (before replacing the tails) and could not get rid of the damn buzzing sound through the speakers. I tried a different amp, sub, cables, etc before finally giving up. I figured I would try again over the winter. Curious to see what you find out on yours, good luck!
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
Great White
Thinking about trimming the amp but didnt have hum before so what could be the difference now. Maybe something to do with the led lights.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
make sure your grounds are very clean and that the connections are solid. if you have the lights grounded where other things/systems are also grounded you could try giving the lights their own ground location as well
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
Great White
Hmmm. I'm not sure but I didn't need to ground the tail lights but the amp is located just under the light so maybe relocate??
