Old 10-24-2018, 06:22 AM   #1
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
LSX F1A guess
My build is getting it's final tune this week. New LSX B15 crate engine, F1A procharger, race inter-cooler, E85, Fore dual pumps, AUS 1300's, FAST intake, long tubes (no cats), Dewitt radiator and all the supporting goodies.
Going to be pulleyed for 15lbs of boost.
Shop is doing a dyno day on Saturday 10/28. I'm not going to see final numbers until then. Any guesses on what the numbers will be?
Big THANKS to Vector Motorsports in Brighton MI for all the work. I'll post final engine bay pics on Sunday. They did some custom fab work to make it look as good as it performs.
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 10-24-2018, 08:40 AM   #2
Juiced1
Drives: 2012 2SS CAMARO 45th
Depends on how that F1A is pullied. It should put down some killer numbers on E85 without a doubt. I'll say 945/849
Juiced1 is offline   Reply With Quote
Old 10-24-2018, 08:52 AM   #3
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
21 pounds should get about 1100. You can do the math from there.
UNRIVALED SS is offline   Reply With Quote
Old 10-24-2018, 09:53 AM   #4
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
Oh man that is going to be a beast. Let me know how much boost you are going to run ?
Are you going to do the 15lbs of boost the LSX recommends ?
What other mods are you doing to get this baby faster ?
Did you change the diff, axles, driveshaft, or are you adding a meth kit as well ?
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 10-24-2018, 11:39 AM   #5
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
in for results!
RealQuick is offline   Reply With Quote
Old 10-24-2018, 12:30 PM   #6
Buschman
Buschman's Avatar
I told them 14-15lbs of boost for now.
Driveline and suspension was done last year. RXT 1200 clutch, G-Force driveshaft and outlaw axles, re-built diff with tru-track/JRE caps/LPW cover 3.91 gears, Pedders bushings, Pegasus sub frame bushings, JPSS 32mm sway bar and Pedders XA coil-overs. Running 17” Racestars with 305 ET street R’s.
Not going with meth yet.
Last build was a forged ls3 big cam nitrous setup. Going to have to relearn how to drive the car!
2018 ZL1
2015 1SS 1LE
Stock...ish
Old 10-24-2018, 12:38 PM   #7
Buschman
Buschman's Avatar
Math isn’t fun. Always been more of a SWAG guy.
2018 ZL1
2015 1SS 1LE
Stock...ish
Old 10-24-2018, 01:58 PM   #8
rgrmoreira13
Oh man that sounds so exciting.
I am saving my pennies for a 416ci boosted stroker but I am going with a D1x cause I don't want that much power. Meth will help with IAT but if you are running E85 that should help with internal temps.
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
Old 10-24-2018, 06:12 PM   #9
Buschman
Buschman's Avatar
I’ll post some pics of the inter-cooler. You’ll see that I’m not too worried about IAT’s.
I was thinking about building a stroker, but then I came across the LSX crate. Saved me time, money and will be more reliable than a stroker IMO.
Two more test and tunes at Milan Dragway this year. I’m going for 10.75@130+. I wanted to make sure I have more than enough car to get there. Should be all about the driver now.
2018 ZL1
2015 1SS 1LE
Stock...ish
Old 10-24-2018, 07:13 PM   #10
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
My F1-A build hit almost 850 rwhp, maxed out with a 3.85 12-rib on E-85. That's a low compression 427 though. I am getting limited by too small of headers.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
Bildo is offline   Reply With Quote
Old 10-24-2018, 07:43 PM   #11
Buschman
Buschman's Avatar
How many pounds of boost did you make on that pulley? The LSX is running at 9:1 compression too.
2018 ZL1
2015 1SS 1LE
Stock...ish
Old 10-24-2018, 09:10 PM   #12
rgrmoreira13
Do you have the stage 2 air to air intercooler or did you went with the air to water intercooler ??
For me I have the stage 2 air to air intercooler. Like I said before all of these things are waiting in the garage until I have the 416 stroker on the 1LE.
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
Old 10-24-2018, 10:46 PM   #13
Juiced1
You're going to want to take those 3.91s out for a lower gear. That is gonna spin like crazy
Old 10-25-2018, 06:29 AM   #14
Buschman
Buschman's Avatar
I went with procharger’s race intercooler.
2018 ZL1
2015 1SS 1LE
Stock...ish
