Old 10-27-2018, 09:54 AM   #1
Camaross44094
Drives: Stock 2013 camaro ss l99
2013 camaro ss l99 going forced induction
Right now I have a few bolt ones. Texas speed LT headers, tsp vvt 2.2 cam shaft, Holley efi sniper intake manifold, a nick Williams 102mm throttle body, and a CIA. I also have a 3200 stall converter. Over the winter I plan on upgrading the rear control arms, upgrading the rear differential, adding 4.10 gears and also porting my stock heads. I'm thinking about also getting some type of forced induction. I was thinking about adding a procharger? I would like to not have to do very many supporting mods right away. I'm not looking to run very much boost right away maybe just start with putting 600 or 650 down first. Any input for upgrades absolutely needed or better ideas then a procharger??
https://youtu.be/SRa7EBjp7Nc
https://youtu.be/X1iWjyd6V2k
Camaross44094 is offline   Reply With Quote
Old 10-27-2018, 10:40 AM   #2
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Honestly, i would skip the 4.10s and porting the stock heads and just throw a TT on there...
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 10-27-2018, 11:07 AM   #3
Camaross44094
I was originally thinking about going TT. Just a heck of a lot more work!
Old 10-27-2018, 01:33 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
4.10s are overkill on FI. 3.45s or 3.27s are perfect for FI...
I had 3.91s and switched to 3.45s...
-Don
747 RWHP 794 RWTQ
Old 10-27-2018, 02:38 PM   #5
schul274
Drives: 2011 Camaro SS2RS, 1970 Camaro SS
with all the N/A mods you've made and want to make, why not just go E85 and push that? there is a 500HP N/A camaro around here, hes looking at going e85 now.
schul274 is offline   Reply With Quote
Old 10-27-2018, 03:34 PM   #6
Camaross44094
Would e85 really help all that much?? I was told on a N/A build e85 wouldn't do much??
Old 10-28-2018, 05:52 AM   #7
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
-Don
I agree and so does the formula!
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 10-28-2018, 09:40 AM   #8
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
Personally, I would go ECS instead of Pro Charger. You will easily hit the low to mid 600's with what you are planning. But like others said, skip the gears. I would invest more in a new fuel system. Go to a dual pump, go 1200cc injectors and a flex fuel kit while you are doing the heads and blower. You will be set up for 800-900 if you want it.
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 10-28-2018, 09:49 AM   #9
Camaross44094
Would I have to do any supporting mods? Like driveshaft?
Old 10-29-2018, 06:30 AM   #10
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
If your looking for 600 crank hp then your stock parts "should" survive for some amount of borrowed time. If 600 wheel hp, you're going to want to look at suspension, axles, and bushings. With that power, wheel hop is going to break stuff.
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 10-29-2018, 07:21 AM   #11
Camaross44094
Yeah I'm looking at the wheel. So I'll definitely start looking into suspension upgrades. Thank you
Old 10-29-2018, 12:17 PM   #12
eLeSthree
Drives: 2011 Camaro SS 6sp
My suspension is all stock. Haven't broken anything yet...
besides the clutch. lol
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 10-29-2018, 03:23 PM   #13
ColdfuzionTN
Drives: 2012 Camaro SS
I second the ECS kit, did mine on 12 SS. Did all the supporting mods first like suspension, drive shaft, rear, solid subframe bushings, duel fuel pump setup, cam, top end, ls3 conversion, and more. Lost the tranny around 650 rwhp, the 6l80e is known for a bunch of issues with cracking drums not to scare you just make sure you know whats gonna break and around when.
With the 3200 stall install throw a tranny cooler on as well save you some grief later. After some more modding and tranny rebuilt beefier I'm sitting at 810 rwhp and only getting about 6 months out of my nitto's. So definitely worth it!
ColdfuzionTN is offline   Reply With Quote
Old 10-29-2018, 05:33 PM   #14
AGP Turbo
Drives: All things Turbocharged
The cost and effort of porting your heads at that power level with forced induction if for sure not worth it. The next weakest link in the car is the stock 6L80 trans. forcus more $$ on upgrading that to a 6L90 out of a ZL1. I'd just TT it for now and upgrade the trans when you can, then turn it up to 800whp on high oct and let it rip.
AGP Turbo is offline   Reply With Quote
