Space Shuttle Aficionado
Car sometimes won’t shift out of 4th
Need your help guys,
This issue started within the last two days. At first I just assumed it was a hiccup, but now it’s happened again and even worse. Today I was on an open road and did a “spirited” pull while I was in drive (as opposed to paddle shift or sport). Moderately braked to a stop and sat for about 10 seconds then very lightly accelerated from a stop. From the start the car didn’t feel like it was in 1st or 2nd. When I got up to 50 mph, the car aggressively downshifted to 4th and stayed there. I got up to 70ish and the car was approaching 5k on the rpm. I started to coast to give the car a second to shift and nothing. I had to brake for the car to finally shift up to 5th, then 6th. The car has 25,000 miles on it. 13,000 of which I put on this year. Trans temp was 180 while this was happening. Any ideas? Gonna start by going through all the electronics first |
376 cubic inches of fun
What happens when you use the paddles? Does the transmission respond to paddle inputs?
Tri-County Camaro SWFL
Can you check your trans fluid level?
#6 |
old school chevy rodder
Sounds like it needs a Dyno tune, headers and high flow cats with a CAI to fix that trans issue...… Or maybe switch fluids out with some royal purple or something; but I like my first idea better and it results in maybe being able to burn rubber much easier and sounding much more macho while eliminating that annoying AFM …..
#7 | |
![]() Taking the car into the shop at 3pm today. We'll see what they say. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
Judging by the RPMs and speed you noted I would think its actually sticking in 3rd not 4th. I know in my L99 if I was at 5k or so in 3rd I would likely be over 90 mph so just thought I'd mention that in case it matters when getting it diagnosed.
#9 |
#10 | |
Texas Speed 7/8" long tubes. Also doing a ZL1 front fascia swap with GFX side skirts and rear diffuser. It's gonna be a different animal for Sturgis.
#11 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
New fluid and filter can work miracles sometimes. Only takes a spec of debris to foul up things in the valve body.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
Hit up Juiced. He gave me a deal on my TSP headers
2011 2SS/RS built 8/24/10
#13 |
A car with 25,000 miles isn't going to be low on transmission fluid unless there's a conspicuous leak, nor does it need a flush, most likely.
Since it paddle shifts OK, it sounds like an electronic or software problem. |
#14 | ||
Oh sweet! Will do. Quote:
