Old 10-29-2018, 01:23 PM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
DSX Flex Fuel kit installed.
I'm getting ready to switch to ethanol and the first step was to install the FF sensor so I can read the ethanol content. I'm sure there's a ton of you guys that run this kit on the SS, and I just wanted to make sure everything looks ok with my install.
I'm not crazy about how the sensor is crammed in there with the other hose routed on top of it, but it seems to be the only way. Is this how yours looks?
I pinned the white wire to the empty pin 40.
I enabled the Flex Fuel sensor in the tune (no math yet) and flashed the car.
Now in the scanner I can see ethanol content of 3.1 percent.
Am I good to go?
I also used some heater hose to cover my fuel line near the headers.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 10-29-2018, 08:57 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
It's a pretty simple physical install. The tuning gets a little gnarly.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 10-29-2018, 11:01 PM   #3
John_C
LSx FTW!!!
Drives: 2010 Camaro 2SS RS
When you get to tuning, do share what you did.
I'm still working on my DSX FF tune.
Cold and hot starts need work. It cranks too long before it fires up.
John_C is offline   Reply With Quote
Old 10-30-2018, 09:40 AM   #4
JANNETTYRACING
JANNETTYRACING's Avatar
Am I good to go?
If you are running pump gas I would expect the E content to be closer to 10%
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 10-30-2018, 04:25 PM   #5
John_C
LSx FTW!!!
Mine is usually 9.x % with 93 octane Exon pump gas.
Old 10-30-2018, 07:21 PM   #6
eLeSthree
This has been worrying me, becuase its always 3.1%, hasnt fluctuated at all.
1158whp 1017wtq.
630whp 658wtq
Old 10-30-2018, 07:25 PM   #7
eLeSthree
Im paying a pro, not even gonna mess with it.
1158whp 1017wtq.
630whp 658wtq
Old 10-31-2018, 09:22 AM   #8
DSX Tuning
Drives: 2019 Corvette ZR1
If you're using HP Tuners, feel free to email your tune file to dave@dsxtuning.com. I'd be happy to check it out. If the sensor isn't activated completely, it won't read properly.
DSX Tuning is offline   Reply With Quote
Old 10-31-2018, 03:13 PM   #9
eLeSthree
Thanks Dave, I'll send it over. I chose the virtual sensor type, maybe I should have gone with "sensor". I used "virtual' when I installed your kit in my buddies 2015 camaro, and his works fine. Maybe 2011 and 2015 differ.
1158whp 1017wtq.
630whp 658wtq
Old 11-01-2018, 04:39 PM   #10
eLeSthree
Thats looks better.
1158whp 1017wtq.
630whp 658wtq
Old 11-02-2018, 07:30 AM   #11
John_C
LSx FTW!!!
You need more fuel pump.
Look at your duty cycle at a mere 1,100 rpm's....
Old 11-02-2018, 11:37 AM   #12
eLeSthree
I think its the PID, its always at 99.6%.
1158whp 1017wtq.
630whp 658wtq
Old 11-02-2018, 04:13 PM   #13
John_C
LSx FTW!!!
Ahh. That's right. I had the same issue now that I recall.
I've used the BETA stable version ever since.
Download BETA version here: https://www.hptuners.com/downloads/
Once you do that, download your current tune off the car and mod it through the BETA from that point forward.
Old 11-03-2018, 09:38 AM   #14
eLeSthree
I’m still on 3.1 or 3.3 i forget. Beta’s scare me. Maybe I’ll try 4.0 first. Am I going to lose all my scanner layouts again, like when 3.0 came out?
1158whp 1017wtq.
630whp 658wtq
