Old 10-29-2018, 11:45 PM   #1
210foo
210foo's Avatar
Drives: 2014 Camaro 1LE
1LE curb rash fixed
So I got my car with pretty bad curb rash on all 4 of the wheels and never really had the chance to fix them until now. just sharing the paint supplies i used to help others later on. i know there is already a sticky thread with info on the paint but i didn't see the stuff i used and mine came out damn near identical to factory paint. I pretty much watched a bunch of youtube videos on the process and went at it so I'm not going to explain everything i did.
I used Rust-oleum self etching primer and VHT wheel matte clear coat purchased from local autozone.
i got the black paint from amazon. just search WA8555 paint and get the "factory pack" 19423 which is the GM WA8555 equivalent. was pretty expensive at about $22 a can but it came out really good. used about a can a wheel for everything.
ill post 2 of the wheels i did so far side to side and then one of the painted wheels next to the original paint on a wheel i haven't done yet to get an idea of match up.
hope this helps someone
210foo is offline   Reply With Quote
Old 10-30-2018, 02:22 AM   #2
chargerfan2
chargerfan2's Avatar
Drives: 2014 Camaro SS 1LE 2SS Summit White
Rims look good. How do you like those tires?
chargerfan2 is offline   Reply With Quote
Old 10-30-2018, 10:34 AM   #3
210foo
210foo's Avatar
Thanks, Not sure yet, I just had them mounted before fixing the curb rash. I've heard good things about them so we'll see. I got them on all 4 corners.
Old 10-30-2018, 11:01 AM   #4
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
How did you determine the number for the base coat?
zz430camaro is offline   Reply With Quote
Old 10-30-2018, 11:06 AM   #5
CreeperRS
CreeperRS's Avatar
Drives: 20’ Chevrolet Camaro 2SS 1LE
Looks good, bro!
CreeperRS is offline   Reply With Quote
Old 10-30-2018, 11:22 AM   #6
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
Well done! I may have to do this myself before too long. I'm amazed at how easily the paint comes off of these wheels. I noticed some small white spots on mine and tried to scrape them off with my fingernail only to realize the white spots were actually the rim underneath and I had just scraped off more paint.
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 10-30-2018, 02:09 PM   #7
210foo
210foo's Avatar
Bunch of Google searching
