Old 10-30-2018, 06:32 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
Ported Throttle Body gains
Hello. I've read tons of reviews with regards to Ported T.Bs and see that it gives you better throttle response. My questions is, will you see any gain in your E.T on the strip?
Thanks,
Jason
Maroon 6.2L SS is offline   Reply With Quote
Old 10-30-2018, 06:35 PM   #2
Leo72793
Drives: 2011 2SS/RS
Thanks,
Jason
Its MAinly for Throttle response bud.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 10-30-2018, 07:47 PM   #3
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Definitely more throttle response than anything else. There were post some time ago where some people were seeing maybe a 1-3 hp gain. You’ll never feel it or see it in your times or mph. I have a stage 2 Bo White TB and really like it. Throttle response is much improved.
HOJO is offline   Reply With Quote
Old 10-31-2018, 06:45 PM   #4
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Probably 3-8 depending on other mods or a tune
VR Baron is offline   Reply With Quote
Old 10-31-2018, 11:00 PM   #5
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
All the 3-5 hp gains adds up to 12-15s
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 10-31-2018, 11:29 PM   #6
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
I’m not sure if I gained any hp or tq from a throttle body, but I did notice throttle response being way better. Had a BKK 102mm throttle body for a year and switched to a nick williams 102mm throttle body because the BBK one kept causing issues. Have way more airflow with the 102mm too
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 11-04-2018, 10:02 PM   #7
FrankNstein1
FrankNstein1's Avatar
Drives: 2010 Camaro SS RS
My stock TB was ported when I bought the car, so no before and after experience or numbers. I just try to read and learn.
Kooks LTH, Haltech CAI, cam, tune, MGW shifter, HRE FF01 wheels
FrankNstein1 is offline   Reply With Quote
