Old 11-01-2018, 12:29 PM   #1
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
valve covers
Are there any Gm/Chevy valve covers for the LS that will bolt on and cover the coils?
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 11-01-2018, 06:32 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Check out Holley, I think they have some for what you are looking for.
Old 11-01-2018, 07:00 PM   #3
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Yes, Holley and SLP both have coil covers along with some other people. Google LS coil covers
zz430camaro is offline   Reply With Quote
Old 11-02-2018, 06:47 AM   #4
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
None that I have found, unless you want cheap plastic bolt over covers. There are a few different options for valve covers, Holley and Proform are the most popular. But those only have different mounts for the coils, they do not cover them. MSD makes some plates that bolt over the coils, but they look pretty tacky in my opinion.
If you really want to clean up the engine bay, pick up a coil relocation kit. They come with all the wiring, custom cut plug wires and mounts, you can put the coils where ever you want.
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 11-02-2018, 09:26 AM   #5
gm2376
gm2376's Avatar
do you have a link to a bolt on relocation kit with the harness for mounting over the covers? something like the katech kit, without having to spend 1k on thier valve covers.
thanks
Old 11-02-2018, 04:37 PM   #6
Buschman
Buschman's Avatar
thanks
Check out Michigan Motorsports.
2018 ZL1
2015 1SS 1LE
Stock...ish
Old 11-02-2018, 05:07 PM   #7
1LEJNG
Drives: Red Hot 2014 1LE
covers
pm me an email address and I'll send a picture. I have some sitting in bubble wrap that I don't need after I went fi.
1LEJNG is offline   Reply With Quote
