![]() Drives: 2010 rs Join Date: Sep 2018
Question on cat delete
I was thinking of doing a cat delete on my v6 camaro, anybody know if the check engine light goes on? If it does what can i do to remove it?
Ive heard some people say you need to get a tune but im not sure what they mean and who would beable to do it. Also if anybody has a video of there v6 with a cat delete please post because im trying to hear what it sounds like. Thank you so much!! |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
It’s going to cause a CEL for sure. Only way to get rid of it is a tune
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
Where do i get it tuned, or can i do it myself?
You can do it yourself if you get a portable tuner. If I were you I would look around for good shops to tune it. Or you can have someone on here do a custom tune and send it to you via email.
Ok awesome! And is it possible to delete the cats at home? With jack stands? Also what kinda materials would i need to perform this task??
#6 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
Not every idea is a good idea.
#7 |
Anybody have a step by step process? Would be really nice!
#8 | |
Not sure. I have an SS lol
#9 |
Its bassiclly the same for the ss and rs?
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
On these cars it's not so much a delete as it is a replacement.
It's not like on the older cars where you are taking a hacksaw to your exhaust and cutting the cats out and then straight piping it. These cars have the cats integrated into the downpipe of the exhaust manifold. So your choices on a 2010 LLT V6 are going to be limited to long tube headers, short tube headers, catless mid pipes, or high flow catted mid pipes. Sorry if you already know all of this, but we have no idea what your knowledge of the platform is, so I figured I would put that out there. Either way, it's going to cost you some money. Your best bet is to start by heading to youtube and searching for cat deleted V6 Camaros and then decide your budget and if you are just looking for sound or both sound and power. What is your goal with this?
#11 |
Trying to get a nice sound bassiclly, not really into performance, what would you recommend? Any step by step guides would be awesome!! Also i dont have much knowledge im a newbie haha.
#12 | ||
1bad6
Drives: 2010 camaro Join Date: Sep 2017
If you’re only going for sound then the shorty headers are the cheaper option, but long tube headers come with alottt more gains Quote:
Mods: trifecta tune on 93 pump gas, mrt v1 Axle-Back, drilled/slotted rotors, 4" quad tips, Res delete, big worm gfx black out kit all around, interior footwell lights.
#13 |
![]() Drives: 2012 ZL1 Join Date: Apr 2015
What kind of sound are you looking for? In my experience just removing the cats does not make it sound better, it makes it sound very raspy and harsh, you need a nice sounding muffler to go with cat deletes. It all depends what you want, but definitely check YouTube!!
2012 ZL1 preproduction car #13 ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet |
#14 |
old school chevy rodder
1st Harry its illegal to remove cats completely, a shop doing so can be fined 10k per car and many would not do it...especially major chains know not to do it. And a high flow cat is the way most go with shorty headers for the V-6 especially your year the early years of the v-6 had separate head and exhaust manifolds compared to newer v-6 so it makes it easier to make a little more power with some high flow cats to keep the rasp down. A properly done set up also may not throw a code BTW..... SO speak to these guys they are the ones the guys use and have used in the past...…
https://solo-performance.com/ or you can buy a tuner for about 400$ for a sxt say from someone like Jannetty racing who can preload tunes into it for free if you buy the parts from them..... and then you have this tuner which is ok for showing OBD 2 codes but basically is a expensive brick especially for someone just doing minor upgrades of a v-6. Good Luck, old timer here.
