Old 11-02-2018, 05:34 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
JBA High Flow Cat Big Daddy O2 extender/simulator
Hey all. I think I made a mistake. I bought a pair of JBA High Flow Cats off of a fella on this site and they came with the original JBA straight extenders and then the Big Daddy L extenders screwed into those. I installed the cats and after 15 minutes I threw a CEL. Was I supposed to only use the Big Daddy L extenders on the High Flow Cat instead of both?
Maroon 6.2L SS is offline   Reply With Quote
Old 11-02-2018, 06:48 PM   #2
Nb1081
Drives: 10 2ss/rs
I have long tubes and hfc and i only used straight ones, and even before tune didnt get codes i didnt get a lot of miles on car but definitely more than the 15 minutes you experienced
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 11-02-2018, 07:03 PM   #3
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
You have to use both. I've ran high flow cats and am now catless using both and I haven't thrown a CEL.
Try just running the straight extenders. 2013+ need both and I've heard earlier models get away with wearing one.
Old 11-03-2018, 08:28 AM   #4
Maroon 6.2L SS
I think I read the same thing about solo cats as well. 2013 and up need the additional extender (Big Daddy L/Vibrant J) and under 2013 just need a straight extender.
Old 11-03-2018, 04:17 PM   #5
sinisterlsx510
sinisterlsx510's Avatar
Drives: 14 ss camaro summit white
Not tryna hijack thread but Im still getting a cel even after my tune.. i wonder if by adding these babies it would help
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe
2019 sierra duramax 2500 all terrain x
2001 trans am
Lsx 408 ci rebuild in progress(dead project)
1967 camaro
Sbc 327.
sinisterlsx510 is offline   Reply With Quote
Old 11-03-2018, 06:01 PM   #6
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
The tuner could turn off the rear O2 codes. No more CEL....
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 11-03-2018, 09:50 PM   #7
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
I've got both on my Solo HF cats but mines a '13 if it really makes a difference? What code are you getting? I got a code when I first added the BigDaddies to the Solo extenders but it was a different code than the one I got before I put on the Big Daddies. I think it was a P013f something like "O2 sensor delayed response" but it was for the rear O2 sensor, I guess it had to do with having two extenders on it. I cleared it and it never came back again.
camguynj is offline   Reply With Quote
Old 11-03-2018, 10:29 PM   #8
sinisterlsx510
-Scott
Pretty much did but they still pop up.. he sayin its cause my brand of headers maybe.
2014 ss camaro
2001 trans am
1967 camaro
Sbc 327.
Old 11-04-2018, 05:32 PM   #9
CamaroDreams76
Theres no "pretty much did". Its either on or off..... at least in hp tuners. Brand should make zero difference unless you are running shortie headers. Either way, the tuner needs to turn them off.
