Old 11-06-2018, 12:35 PM   #1
graf101
Trouble_SM
graf101's Avatar
Drives: 17' Summit White ZL1
RPM 4L80e shifting issue
I have an RPM stage 5 4L80e in my 2015 1LE and have begun to experience a delayed 1-2 shift or it will bang off the rev limiter. This has started to occur in the cooler weather, so my initial assumption is that the engine is making a little more power with the cooler weather and better DA, so the engine is hitting the RPM much quicker than what the TCM controller is tuned at. I tried tweaking the shift points and mph, but it doesn't seem to help on the 1-2 shift. Is the transmission sprag out internally or could it be a tuning issue? I am running the PCS TCM 2800 and it can be data logged, but I don't really know what I am looking for. Any help is appreciated.
graf101 is offline   Reply With Quote
Old 11-18-2018, 11:32 PM   #2
scotty9794
Drives: 2011 ss/rs
I had posted a reply after you put one on my similiar issue post. My issue wound up being my converter. It was "rebuilt" by the manufacturer, but after 100 miles it began slipping. By 250 miles it was glaringly apparent it was faulty. Trans builder went through it and i had no issue other than some heat damage to the clutches and intermediate discs. Theyre replaced now to be safe. Waiting on converter again. It wouldnt shift because the slipping didnt let it build enough pressure.
TMS forged 376, 237/239 cam, AGP kit w/ s256 twins and race intercooler, Alky dual nozzle meth system, FIC 127lb injectors, Fore dual TI 450s, Jakes stage 4 4l80e, Circle D triple disc billet 3400 stall, DSS aluminum shaft, eBoost 2 controller, BMR toe rods-adj lower control arms-adj trailing rods, and bushings, nt555r rears.
scotty9794 is offline   Reply With Quote
Old 11-20-2018, 04:57 PM   #3
graf101
Trouble_SM
graf101's Avatar
That sounds like it could be my issue! Thanks for the info!
