Old 11-07-2018, 04:37 PM   #1
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Drives: 2019 /2SS LT1
L99,gear swap..does or will it need a Retune?
I have a 3200stall on factory gears..curious if i need a retune for each shift point or just a speed recalibrate
2019/LT1 2SS
RLNTLSS is offline   Reply With Quote
Old 11-07-2018, 04:54 PM   #2
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Retune
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 11-07-2018, 05:05 PM   #3
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
For each shift point?
2019/LT1 2SS
Old 11-07-2018, 07:12 PM   #4
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
With a stall and gears you need to retune for sure.
rontammy0 is offline   Reply With Quote
Old 11-07-2018, 07:47 PM   #5
Juiced1
Drives: 2012 2SS CAMARO 45th
When you enter the new gear info it will update all your shift mphs. The rpm should shift points would stay the same.
If you don't update your tune your speedo will be off which can add mileage to your car faster (not cool).
Most tuners (us included) will not charge a full tune rate just to update the gear size. In fact if we have already tuned your car and paid for the vin we would do something like that as a no charge.
Juiced1 is offline   Reply With Quote
Old 11-08-2018, 06:46 AM   #6
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
If i step up to 391s in my l99 thats already tune for cam and headers my tuner will just readjust the speedo..the gear swap is an input in hp tuners that corrects everything?
2019/LT1 2SS
Old 11-08-2018, 08:59 AM   #7
Juiced1
Correct
Old 11-08-2018, 09:09 PM   #8
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Can this be used after the initial flush of the new gears..cant seem to get a straight answer on the search function.. its ac delco differential with modifier https://www.gmpartsgarage.com/oem-parts/gm-oil-88862624
2019/LT1 2SS
Old 11-11-2018, 10:48 AM   #9
Juiced1
Yeah that will work fine.
