Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Transmission / Driveline
Old 11-08-2018, 12:04 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
Thumbs up RST Polyurethane Transmission Mount @ Phastek Performance
Now Available!
FREE Shipping @ Phastek Performance
Race Sport Technology (RST) has come out with a solution that will take care of movement caused by the soft factory rubber transmission mount. The polyurethane used in their design can hold its shape better than rubber with less flexing of the material, which means more energy can be delivered to the rear wheels. This allows for harder launches and helps maintain the proper pinion angle with less transmission movement.
Fits 2010-2015 Camaro SS & ZL1 with Manual Transmission
Installation is done by simply removing the factory mount and installing the polyurethane mount. You will need to support the transmission with transmission jack or something equivalent, then you can remove the factory transmission brace allowing access to the factory rubber mount. Then you can simply unbolt the factory mount and replace with the RST Polyurethane mount using the factory bolts. Then you can reinstall the factory transmission brace in reverse order as removed.
Features:
  • Direct bolt-in
  • No modification required
  • Less driveline movement
  • Constructed out of Polyurethane
  • Enables harder launches
  • Made in the USA
RST - 5PTM
Sales@Phastek is offline   Reply With Quote
Old 11-09-2018, 02:05 AM   #2
Dylan1214
Dylan1214's Avatar
Drives: 2014 Camaro SS L99
Why no auto :(
Dylan1214 is offline   Reply With Quote
5ptm, polyurethane, rst, transmission mount
