![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS, 2010 Camaro SS Join Date: Apr 2012
GOING ON NOW!!
FREE SHIPPING @ Phastek Performance ![]() Black Friday Deals are here early at Phastek Performance! We are offering 5% off on 10 brands. 10% off on 39 different brands and 20% off on two brands. Best part on the 20% off the discount is already applied to the items, no discount code needed! Black Friday Deals came early so here are the links to the website so you can start shopping. SAVE 5% ON 11 DIFFERENT BRANDS WITH CODE: BFCM5 ![]() SAVE 10% ON OVER 35 DIFFERENT BRANDS WITH CODE: BFCM10 ![]() SAVE 20% ON VERTICAL DOORS AND AIRLIFT PERFORMANCE, ITEMS ARE ALREADY DISCOUNTED!
Space Shuttle Aficionado
Drives: 2016 Camaro 2SS Join Date: Jun 2010
Can these discounts be used with the Camaro5 discount code as well?
Unfortunately not. Discount codes can not be compounded to work together.
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS RJT Join Date: May 2009
Hendrix urethane ofset diff bushings
Hi, do you have in stock or plan to stock a set of the Hendrix offset differential bushings in urethane ?, I do not want the delrin bushing kit. Thanks...Ed.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
| Tags |
| black friday, camaro, phastek, phastek performance, sale |
