Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Knucklehead move...
Man, I'm feeling now too...
So, last weekend I went for a drive... it was late, around midnight. Yeah, sometimes I just go for a drive lol... Anyway, needed gas. After a nice run up I15, I hit one of my usual watering holes... The ride was about an 1/8th from empty. I stopped and began pumping gas. I was 6 gallons in before I noticed I was putting 87 Octane in it!! ![]() Crap! WTF! Not cool... never have I ever! It was late and to my defense, I put 87 in my work pickup truck... but in the Camaro?!?!? NEVER BEFORE! Anyway, stopped pumping immediately. Started again with 91 but quickly remembered I had one of those LUCAS Fuel injector cleaners with octane boost in the trunk... supposedly, ya don't need to use hi octane fuel with one of those. Hmm... I added the stuff to my tank, and pumped 8 more gallons of 91 Octane. I'm not worried per say, but I am concerned about having to drive with about half a freakin tank of low octane fuel... and to top it off, I feel it. It seems that the Lucas stuff didn't work before the fuel mapping on my car seems to have taken a step back to 87 Octane. I reckon I just have to burn it off before I pull the 5 and 20 again and/or retune... Just had to share this knucklehead move... moral of the story, Watch what you're doing lol |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
Won't hurt anything. Run it until just about empty, fill with 91 and do the fuse pull .. everything should be as it was
There are 91 octane stickers on ebay. I know in Oregon it helps because you cannot pump your own fuel there. It may serve as a self-reminder too!
416HP, 422TQ. Rotofab CAI, Dyno Tuned. ALP's and a V1. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
As long as you still have a proper low octane spark map you’re good. Run it empty and fill with 91
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
#6 | |
![]() Drives: 2013 Summit White 2SS/1LE Join Date: Jul 2018
![]() Needless to say, word got around the office and by the time he was back from his trip someone had printed up a big sticker that said "Diesel Only" and put it on his desk to welcome him back. Boss wasn't too thrilled, as the repair to flush the tank and replace filters, seals, etc. was pretty expensive. Overall, not the most fiscally productive sales trip for my associate. Lol. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Miss Con Ception Join Date: Aug 2016
When the school bus stops next to you at a stop signal bury your face in your hands.
2011 1SS/RS LS3 CGM
#8 |
#9 | |
A diesel motor will run on gasoline, it will just have no power. All you have to do is run it out at idle or drain the tank, then refill with diesel. It will puke and smoke for a bit, but then clear. It won't ruin any filters or seals. Someone ripped you on that. Now, diesel in a gasoline engine, it will blow the intake off as soon as it hits the intake manifold.
2011 1SS/RS LS3 CGM
#10 |
![]() Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
That law changed recently. You can self-service in Oregon now, but that sticker would be necessary for sure if someone other than me was putting gas in my car.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
#11 | |
The dealership may have overbilled for unnecessary labor on cleaning the lines & replacing the fuel filter though. You're probably right about that. |
#12 |
#938 of 1524
Drives: 2013 Hot Wheels Edition Camaro Join Date: Mar 2017
You could run a gallon or two out, then fill it back up with the good stuff. That'll let the good gas mix in with the cheap stuff. Do this 3-4 times and you should be good to go.
#13 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
91? I shudder at the thought. My baby runs on 93 only. We stopped at a gas station and I saw it only had 92 so I left and went down the street to one that had 93. Wife just rolls her eyes. She just doesn’t understand.
![]() How about keeping a bottle of that 104+ octane booster in the trunk? I always wondered if I should do the same next time we travel. |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
I did the same thing this summer. Pulled up to a pump and just about to hit the 93 button. When a older gentleman and his wife distracted me and wanted to know about my car. On the way home I had a {BRAIN FART} something was wrong.
Looked at my gas receipt and right away saw the price of gas and new I did the unthinkable and put 87 in the car. I got home and put fuel conditioner in then drove it to mix everything. Car had a little chug to it. Burned off a few gallons and top off with 93. Drove it some more and straightened it self out.
