Old 11-19-2018, 12:49 PM   #1
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Need to remove starter for new flywheel ?
Does the starter need to be removed, loosened, shifted out of the way, wires disconnected, etc. to install a new clutch and flywheel ?
camguynj is offline   Reply With Quote
Old 11-19-2018, 02:28 PM   #2
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
No.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 11-19-2018, 04:34 PM   #3
cypressh
Canadian
cypressh's Avatar
Drives: 2011 Camaro 2SS/RS
It does not have to be, but 9/10 you will, 1 less thing in the way.
2011 Camaro SS/RS
The cars we drive say a lot about us.
cypressh is offline   Reply With Quote
Old 11-19-2018, 04:36 PM   #4
camguynj
camguynj's Avatar
Thank You! That’s what I thought as I didn’t see any mention of the starter in any write up or video but I didn’t want to assume as you know what that can lead to
Saw this photo of the starter bell housing cover that's attached to the block between the starter and the bell housing. Look like it seals the starter to the bell housing when the bell housing is mated onto the block
