11-26-2018, 09:26 AM | #1 |
LS3 150k mile oil type test
My stock bottom end is tired. Doesnt run near as strong as it did even a year ago. My oil pressure isnt impressive either. Not bad but not what I remember not too long ago. I decided to swap to a thicker oil. Been running Mobil 1 10w30 since day one with awesome success. 2 Blackstone tests with rave reviews. I was going to try a 20w50 so imo of whats best thats readily available over the counter anywhere is the Valvoline VR1. My results:
Mobil 1 10w30 47lbs cold idle/22lbs hot idle Valvoline VR1 43lbs cold idle/30lbs hot idle |
11-26-2018, 09:51 AM | #2 |
old school chevy rodder
Yup I used Vr1 conventional high Zddp for part of my break in on my engine, I should soon get some Z max to throw in for wear but I use Driven racing oil and its full synth after 20k or so now with it and I don't get high in miles like you pile on.
Its good your pressures back up I know your pumps a high volume eventually you will need a over hone or new short block. I got my short block bare for about 1400 from Jerry at custom engine supply/Sag performance but he's in Angola, anyway its a thought I love my stroker it makes hay....., I have good luck and about 40lbs hot and that's happy for me, I used to try to keep up above 30 with SBC/BBC and that's a good rule for a healthy engine. https://www.drivenracingoilsales.com/ I have been real happy with the Ls30 full synth so far only blows by and burns maybe 1/4 -1/2 quart in 5k at most, ( clean my catch can once in a while0. This site says cases ship for free, even better than having to go order it over the phone to the local Baxter auto supply here. You have the cross member MOD I believe and could check things as far as the bottom end easier than anyone on here... Anyway damn Norton keeping a fake form attack kicked out on Driven racings regular site WTF.... and that's crap... this bulk sales site works and of course its available at jegs and summit and etc etc and they do make higher viscosity oils for larger tolerances for hot rods....I don't see anything in particular saying high mile oil...
11-26-2018, 10:27 AM | #3 |
Drives: 2015 1LE Join Date: Oct 2015
Time for a fresh rebuild?
11-26-2018, 02:15 PM | #4 |
Yes. Will pull it soon.
11-26-2018, 02:26 PM | #5 |
Got to tip your hat to an engine that's been through all the different configurations yours has with no major failures!
11-26-2018, 02:30 PM | #6 |
Some higher compression, valve relief pistons would be nice.
11-26-2018, 04:37 PM | #7 | |
Drives: 2013 1SS 1LE Join Date: Jun 2016
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
11-26-2018, 05:40 PM | #8 |
I run royal purple 20w50 HPS, it has the zinc in it. I think the zinc helps with any high performance engine even if it does not have a flat tappet cam. Plus the 20w50 made the valve train much quieter. I just make sure the oil temp is 190+ before it goes full trottle. I also run a Melling standard volume, high pressure pump so the sump has enough in it. Going to add a crank scrapper in the spring to help control that thick oil.
11-26-2018, 10:07 PM | #9 | |
Drives: 2014 Camaro 1SS Join Date: Jun 2010
Have you considered swapping the oil pump for a melling high volume high pressure unit. I think the intended use is higher mileage engines. I have one and the pressure runs about 3.9 bar cold, about 2.8 bar hot. I'm at ~113k miles now. I run mobil 1 5w30 - also 8oz of Red Line engine break in additive at oil changes for extra zinc & phosphorus. I think you posted a compression test a while back that looked pretty good. That LS3 is just getting broken in at 150k.
2014 1SS - BTR Stg3, GMPP CNC Heads, Kooks LTs & cats, Magnaflow 2.5" Street w/Res X, Z28 CAI
Last edited by marklsx; 11-27-2018 at 09:18 PM. Reason: corrected miles, brain not working |
11-27-2018, 02:02 AM | #10 |
Mine has a Melling HV pump that I put in during my first cam swap.
11-27-2018, 02:04 AM | #11 |
11-27-2018, 08:49 AM | #12 |
you must be about 150k ? on it...…. Planning on zmax just to see if over the long run it helps at 50k intervals now that its broken in well and worn well in with 20k on this engine.
11-28-2018, 01:07 AM | #13 |
Drives: 13' 1LE Join Date: Apr 2012
LS3 are stout engine to run modified for 150k miles. Of course owner knows what hes doing. Do you think HP pump would be better than HV? Oil is helping for the pressure a bit!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
11-28-2018, 01:28 AM | #14 |
Nah Im a volume guy as long as pressure is at acceptable levels.
