Old 11-26-2018, 12:39 PM   #1
VRZL113
VRZL113's Avatar
Drives: 2013 VR ZL1, M6
Reupholstered my driver seat cushion
Hey guys, I finally got around to installing a new drivers seat cushion cover in my ZL1.
The previous owner had 3 little stains that would not come out of the suede, and they drove me nuts.
Install wasn't bad at all (see photos below).
Part# 23161532
Instructions:
1. Remove seat from car (2 torx T-50 bolts, detach wire harness, and tip forward and out).
2. Remove plastic trim along side of seat (2 Phillips head screws).
3. Unclip seat cover from seat frame (3 points of contact... front and both sides).
4. Start lifting seat cover up and off foam padding (you will start to reveal the hog rings).
5. Remove all hog rings via needle nose pliers.
6. Disconnect the wire harness that runs from the seat back to the seat bottom.
7. Pull seat cover through the portion of the seat back and seat base (you have now removed the bottom seat cover).
8. Installation is the reverse of removal except I chose zip ties vs. dealing with new hog rings (made installation a breeze).
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
VRZL113 is offline   Reply With Quote
Old 11-26-2018, 03:03 PM   #2
Coop[580
Coop[580's Avatar
Drives: 2012 ZL1 Ashen Grey
Did you do both upper and lower?
2012 M6
Kooks 1 7/8, off road pipes , full corsa exhaust ID1300s/ 22% lower / 2.5 upper, JLT CAI, DSX flex fuel, DSX AUX fuel pump. S19 cam
Tuned and built by Speed Inc
635/632-93 octane
725/738-E85
Coop[580 is offline   Reply With Quote
Old 11-26-2018, 05:10 PM   #3
GONMAD510
Drives: 2013 ZL1 M6
Looks good. Any special tools needed?
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
Old 11-27-2018, 01:29 AM   #4
ZEDL1
Drives: 2013 ZL1 Triple Black, 2015 2LT/RS
Very well done. Perfect finish.
ZEDL1 is offline   Reply With Quote
Old 11-27-2018, 12:46 PM   #5
VRZL113
VRZL113's Avatar
I only replaced the lower section. Upper was mint.
Old 11-27-2018, 12:47 PM   #6
VRZL113
VRZL113's Avatar
Thanks. No special tools required unless you choose to use hog rings to reinstall. If so, I'd suggest the hog ring pliers.
Old 11-27-2018, 12:48 PM   #7
VRZL113
VRZL113's Avatar
Thank you!! Now I don't have to be ashamed of the little stains when I show people the interior of my car, Lol.
