Old 11-26-2018, 10:16 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
WTB LSA heads
Hit me up with what you’ve got!
Nighthawk89 is offline   Reply With Quote
Old 11-27-2018, 01:42 AM   #2
lxinms
Drives: 2001 Camaro SS & 2005 Canyon ZQ8
PM sent.
lxinms is offline   Reply With Quote
Old 11-28-2018, 07:03 PM   #3
ADM PERFORMANCE
Drives: Anything I want
I have plenty of CNC Ported LSA and LS3 heads in stock. Turn key ready for $1100 a pair no core
ADM PERFORMANCE is offline   Reply With Quote
Old 11-28-2018, 08:26 PM   #4
Nighthawk89
I ended up ordering a set of the AFR mongoose heads guys. Thanks for your PM’s and responses.
Old 11-28-2018, 09:11 PM   #5
ADM PERFORMANCE
Before you mount them up, be sure and clean up the spark plug threads.
In other words install some and make sure they start easy.
Old 11-28-2018, 09:27 PM   #6
Nighthawk89
Andy, Have you ran the Mongoose heads before? Thoughts?
Old 11-28-2018, 10:41 PM   #7
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Good choice on heads! I bought a set of Mamo-fied AFRs for my ZR1.
Thanks for the spark plug hole tip Andy.
Old 11-28-2018, 10:54 PM   #8
Nighthawk89
I did a bit of research before purchasing them.. looking forward to checking them out! Just have to decide if i wanna run the LS9 Gasket or use a LS7 gasket.. Seems like the bore sizing of the LS7 gasket is better suited for the heads but not sure if the material/make of the LS9 is of better quality...
Old 11-28-2018, 11:08 PM   #9
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I am running Cometic 5318-040 as recommended by Tony Mamo. They have a 4.160 bore. The AFR site specifically mentions them also.
Look under the recommended components section
I also bought the 6 bolt version just in case the LS9 block ever has to go and I go with a 6 bolt block.
Old 11-28-2018, 11:29 PM   #10
Nighthawk89
I am looking at the cometic website and i notice they offer a .51 thickness and then a .56 thickness in the 4.160'' bore.. Not sure which one to get considering the LS7 measures in at a .51 thickness and the LS9 gasket at a .55.. Not sure which cometic would work the best?
I did the exact same.. I went with the 6 bolt version as a safety measure.. Who knows.. May want to upgrade down the line..
Old 11-28-2018, 11:51 PM   #11
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Either will work. Consult your builder and/or tuner?
