Old 11-29-2018, 08:49 AM   #1
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
Katech Belt tensioner and a ECS
Will the katech belt tensioner work work with a east coast supercharger? I am guessing yes, since it doesn't share a belt with the supercharger, but just looking for a positive yes.
Thanks
https://store.katechengines.com/bill...sioner-p2.aspx
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 11-29-2018, 05:44 PM   #2
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
I have one on mine, but I’m running a F-1A procharger.
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 11-30-2018, 01:18 PM   #3
Buschman
Buschman's Avatar
Here is a the best pic I could find showing it. Car is in the shop having some winter work done!
2018 ZL1
2015 1SS 1LE
Stock...ish
Old 11-30-2018, 05:42 PM   #4
TheInfamouSS
@LS.ACE
TheInfamouSS's Avatar
Drives: 2014 Chevy Camaro 2SS/1LE
If you are the one that posted on FB im sure we have talked. But yes it works. Yes its great. Yes get it. BTW im Rob Ace on FB.
Some weird snail with a belt on it | Tial Q Bov | CCP Jam Cam | Stainless Works 1 7/8" Headers to Custom 3" Exhaust | Alky Control Dual Nozzle| ProMeth Trunk Mount Tank | Melling Oil Pump | DSX Aux Pump | id1050x Injectors | McLeod RXT w/ Monster Billet Release Bearing | ZL1 3.73 Rear Diff | BMR Delrin/Poly Diff Bushings | DSS 1-Piece Aluminum Driveshaft | ZL1 Axles | Metco Driveshaft Loop | BMR Adjustable LCA's, TA's, Toe Rods | BMR Adjustable Sway Bar w/ Fe3 End Links | Mickey Thompson 305/35-20 Street S/S Drag Radials |
TheInfamouSS is offline   Reply With Quote
Old 11-30-2018, 05:43 PM   #5
gm2376
gm2376's Avatar
Haha. Yep, that was me. I had this up here at the same time. Thanks!
