Old 11-29-2018, 05:24 PM   #1
mgb
mgb's Avatar
Drives: 2010 ABM 2SS - 2012 ZL1
Remote start not working
Bought a 2012 zl1, was told the remote start worked. Followed the directions, lock doors, hold for a couple of seconds, can hear a noise like it's trying to do something for a 3 or 4 seconds, but nothing happens. Any suggestions?
mgb is offline   Reply With Quote
Old 11-29-2018, 05:25 PM   #2
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Mine sometimes acts up, press lock twice and hold auto start.
SSEssence is offline   Reply With Quote
Old 11-29-2018, 06:37 PM   #3
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
If you have a CEL the remote start won’t work. Just in case you have a CEL lol. And I also think it doesn’t work if the key fobs battery is dying. Not sure though
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 11-29-2018, 06:57 PM   #4
mgb
mgb's Avatar
How do you like your CFD shifter? I'm thinking about one of those.
Old 11-29-2018, 06:59 PM   #5
mgb
mgb's Avatar
What's a CEL?
Old 11-29-2018, 06:59 PM   #6
krisprz2010camaross
Originally Posted by mgb View Post
What's a CEL?
Check engine light
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 11-29-2018, 07:00 PM   #7
mgb
mgb's Avatar
That's one sharp ride you've got!
Old 11-29-2018, 07:11 PM   #8
SSEssence
Instagram: Sangstah
Love mine, wouldn't have it any other way and love the old B&M t handle throwback look.
Old 11-30-2018, 05:03 AM   #9
mgb
mgb's Avatar
Do you have any pics?
Old 11-30-2018, 05:06 AM   #10
mgb
mgb's Avatar
Check engine light
Thanks - No CEL, but I will have - Service Suspension come up on message window
Old 11-30-2018, 07:40 AM   #11
mgb
mgb's Avatar
Would this keep the remote from working?
Old 11-30-2018, 09:21 AM   #12
robrocketanski
robrocketanski's Avatar
Drives: ZL1 Convertible Auto
  • A current vehicle DTC that illuminates the malfunction indicator lamp (MIL)
  • The vehicle is in valet mode
  • On passive entry equipped vehicles, an additional key fob is left in the vehicle
  • More than 2 remote starts have been attempted
  • The hazard switch is in the ON position
  • A current hazard switch DTC is set
  • The vehicle hood is ajar
  • A current hood ajar DTC is set
  • A current door ajar system fault
  • A vehicle door is ajar
  • Incorrect BCM software is installed and vehicle start is not enabled
  • The content theft deterrent system detects an alarm trigger
  • Excessive engine RPM
  • Excessive coolant temperature
  • Accelerator pedal position greater than 0 percent
  • Vehicle not in park
  • Vehicle theft deterrent malfunction
  • A current automatic transmission shift lock control system DTC is set
  • A vehicle speed sensor signal is detected by the ECM
LS3 intake and throttle body, Huron Speed Products twin turbo with 6265 oil less turbos, and 3" header back, JRE smooth cam, ID1300, Fore dual 450lph pumps with MSD voltage booster, A6, 305/45/17 MT Street R
robrocketanski is offline   Reply With Quote
Old 11-30-2018, 09:22 AM   #13
robrocketanski
There's a list of things that will prevent it from starting. Yes the Service Suspension message means the car thinks something is wrong so it won't remote start.
Old 11-30-2018, 04:50 PM   #14
ZEDL1
Drives: 2013 ZL1 Triple Black, 2015 2LT/RS
mgb, I very recently had this issue with my 2015, and posted a thread here asking for insights.
My DIC display was reading "Service Stabilitrac", which is what you seem to be expecting.
The input given to me was to disconnect the battery, wait a bit (I waited for about 20 minutes), reconnect and all should be good. The battery is very simple and quick to access.
After I did this, all was perfect.
The remote start function will not operate with a CEL showing.
Try what I did and you should be fine.
There was no objective reason for my DIC reading, if it helps with you situation. Best of luck. Let us know.
ZEDL1 is offline   Reply With Quote
