Old 12-01-2018, 05:16 PM   #1
fastblack10ss
Drives: 2010 SS M6
DSX Flex with TVS2300 fuel line help
Trying to put on the DSX flex fuel kit and the fuel line that came with TVS2300 kinks if I try connecting sensor to fuel rail then TVS fuel line into it.
Any suggestions or pictures of what you did? Also now I can’t get the tool in to release the fuel line from sensor...not enough gap for it to fit.
fastblack10ss is offline   Reply With Quote
Old 12-01-2018, 05:20 PM   #2
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Can you provide any pics of your issues?
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 12-01-2018, 08:23 PM   #3
fastblack10ss
Drives: 2010 SS M6
This is fuel line that I attached flex fuel. So the line kinks to the left side. I’ll try to get picture later of the setup with kink.
Old 12-02-2018, 12:19 AM   #4
fastblack10ss
Drives: 2010 SS M6
I didn’t put the sensor back on rail because it was a pain to get off but should be able to see where the line will link or the left side. Also see not enough space to get tool to remove sensor from fuel line.
Any suggestions?
Old 12-02-2018, 09:35 AM   #5
DSX Tuning
Drives: 2019 Corvette ZR1
Break off the pieces of the disconnect tool that actually need to get in there, and use a screwdriver or two to push them in and release the clips. That's how I unhook them.
The bummer is that the connection point is so damn close and their hose is so short that there aren't a lot of options. You may be better off with a custom hose.
DSX Tuning is offline   Reply With Quote
Old 12-02-2018, 09:50 AM   #6
fastblack10ss
Drives: 2010 SS M6
Do you recommend putting sensor on rail or line coming up to engine bay? Does the direction of flow matter?
Thinking either longer hose or one with a 90*...any suggestions best/easiest place to find hose already made or items to make custom hose?
dsx, e85, flex, fuel, tvs2300
