Old 12-02-2018, 12:23 PM   #1
dennisp98
Drives: 2015 1LT Camaro // 1979 Z28 Camaro
Dual tips on 2015 1LT?
Sorry if this has already been discussed, but has anyone here had any luck with dual exhaust tips on a 2015 1LT without swapping the diffuser? Are there any dual tips that will fit?
dennisp98 is offline   Reply With Quote
Old 12-02-2018, 01:08 PM   #2
silverstorm
silverstorm's Avatar
Drives: 2014 Camaro 2LS
What I plan on doing with my diffuser is getting a reciprocating saw and cutting off what's needed towards the middle instead of paying $300 more for a piece of plastic. I have NPP mufflers and the tips on those are much bigger, so in my opinion I wouldn't go with smaller tips than what you already have
silverstorm is offline   Reply With Quote
Old 12-02-2018, 05:41 PM   #3
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
If you don't swap the diffuser you'll need quad tips that fit in a space normally occupied by a 4-5" single tip.
DSX_Camaro is offline   Reply With Quote
Old 12-03-2018, 08:04 AM   #4
Yellow Bullet
Yellow Bullet's Avatar
Drives: 2017 Chevy Sonic RS 1.4T
Dual tips are standard on any Camaro, you meean quad tips?
2015 Camaro RS/SS SIM LS3- Sold
2017 Sonic Mosaic Black RS 1.4T
Yellow Bullet is offline   Reply With Quote
Old 01-04-2019, 01:17 AM   #5
Zezima
Zezima's Avatar
Drives: 2014 Camaro 2LT/RS
That is going to look terrible, don't look for that. Just buy the rear valance and do it right
Zezima is offline   Reply With Quote
Old 01-04-2019, 06:14 AM   #6
Mike J
Mike J's Avatar
Drives: 2015 Topless Btch RS
Yup
Mike J is offline   Reply With Quote
Old 01-04-2019, 10:12 PM   #7
KillboyPowerhead
Drives: 2015 Z/22
I bought my NPP diffuser from the dealer for ~170 or so, and I'm in Canada where we pay a pant load more for everything for some reason, so you can probably get a new one from the dealer for a decent price, maybe ~100 or so.
KillboyPowerhead is offline   Reply With Quote
Old 01-05-2019, 11:12 AM   #8
DSX_Camaro
DSX_Camaro's Avatar
For a '14/'15, GM lists the number as 22829477. It's around 150 on gmpartsdirect
1lt, exhaust
