Old 12-03-2018, 08:15 AM   #1
Jc_SourPatch
Drives: 2014 2LT Camaro RS
Bad clutch
So I have 70,000 miles on my car and my clutch is going out or at least I think so. So looking for clutch kits. What’s the best one
Jc_SourPatch is offline   Reply With Quote
Old 12-03-2018, 08:34 AM   #2
JooktheSnooke
JooktheSnooke's Avatar
Drives: 2010 camaro ss
look into Exedy
2010 Cyber Gray Metallic 2SS/RS LS3 6 Speed -- Rotofab CAI | Stainless Works Longtubes w/ high flow cats | Muffler Delete | TSP 229/244 stage 2 cam| TSP .660" Spring Kit | TSP CNC Ported Heads | Mulling high volume oil pump | PTB | Trunnion upgrade | Hurst short throw shifter | Elite Engineering Catch Can | Exedy stage 1 clutch |
JooktheSnooke is offline   Reply With Quote
Old 12-03-2018, 10:26 AM   #3
SneakySS
OEM? Whats that?
Drives: 2014 Camaro SS Black Widow
Mcleod twin disk
2014 Southern Comfort Black Widow SS LS3
Magnuson Supercharger, ceramic coated ARH headers w/cat deletes, BTR blower cam, Mahle forged pistons, AEM Methanol injection, JRE 8 rib Super tensioner, Innovators West 8 rib serpentine pulley system, Melling high flow oil pump, Lingenfelter high flow fuel pump, McCleod RXT ceramic coated Twin disk clutch, Hooker BlackHeart exhaust. Escort 360 radar detector & dashcam.
Rockford Fosgate 1000w prime amp, 2X12” Rockford P3D2’s
Build and mods done by R&D Motorsports in Baton Rouge
Tune/Dyno done by ,,Engine Power Systems in Baton Rouge
SneakySS is offline   Reply With Quote
Old 12-03-2018, 11:20 AM   #4
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
The "best" clutch and the most practical clutch for your application are probably 2 different things. No mods listed, so assuming there are none. A stock replacement will probably work fine and you can save some money.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 12-03-2018, 01:21 PM   #5
12blkgrayRS
12blkgrayRS's Avatar
Drives: 2012 Camaro RS 2LT 6spd man
Is it slipping or slow to react to the pedal? Mine does that. but it drives fine the rest of the time, I just think the slave my need bleeding.
12blkgrayRS is offline   Reply With Quote
Old 12-03-2018, 04:43 PM   #6
Jc_SourPatch
Full bolt on. E-85 kit, intake manifold, ARH catless down pipes, overkill tune, CAI cold air intake.
Old 12-03-2018, 10:46 PM   #7
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Monster twin disc. Upgrade the master cylinder with an Ideal Garage unit and get the Monster billet slave piece also.
DSX_Camaro is offline   Reply With Quote
Old 12-04-2018, 08:02 AM   #8
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Still need to know more about the car. Do you race the car at all? If so are you launching on a street tire or something stickier? Stock replacement is fine for a full bolt on car that doesn't get raced. If you're a regular at the drag strip you might as well spend the money and get something that will hold up better. These guys are 100% right, if the trans is coming out, make sure it goes back in with a billet throw out bearing support and a speed bleeder. The bearing support is a very common failure point, and the speed bleeder will make your clutch hydraulic system maintenance much easier. A remote reservoir is also a worthwhile investment for cars that see any sort of aggressive use.
From my research, if I was going to put a clutch in, it would be a Mcleod RXT. Has a great reputation for both driving nicely and taking all the abuse you can throw at it.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 12-04-2018, 05:55 PM   #9
DSX_Camaro
DSX_Camaro's Avatar
(This is on a V6 just so we're clear) I'm pretty confident there isn't a McLeod option for the V6. Also why I recommend the Monster twin disc unit. Holds power much better but drives like stock. A friend of mine has gone through a Spec clutch and some other brand, single disc units, and his car felt, I dunno, squishy to drive compared to mine, grabbed much slower. I am a believer in the twin discs.
Old 12-04-2018, 11:17 PM   #10
Jc_SourPatch
Monster is what I’m looking at but why should I get the master cylinder and slave cylinder?
Old 12-05-2018, 08:54 AM   #11
zlathim
zlathim's Avatar
At the very least replace the slave cylinder because it requires removing the transmission to replace. It's cheap insurance as far as I'm concerned. (I am assuming that the slave is located in the same place on the V6 & V8 models.)
The master cylinder is easier to replace, so I didn't worry about it when I had mine apart.
Opinions differ, so keep that in mind when evaluating what everyone is telling you.
Tuned by GPI
Old 12-05-2018, 11:35 PM   #12
DSX_Camaro
DSX_Camaro's Avatar
I swapped my master cylinder to the Ideal Garage unit like I said when I did everything. It's easy and relatively cheap and the pedal feels much better. But feeling is an opinion. Do you need it, probably not.
Slave should be replaced every time you replace the clutch. If you go Monster, just get the slave from them with the billet support. You'll pay for one regardless.
