Old 12-06-2018, 09:32 AM   #1
Harry16
Drives: 2010 rs
Anyone know howto make there v6 exhuast pop and crackle?
As title says does anyone know how? Currently I have an x pipe and magnaflow mufflers, would I need to delete cats?
Harry16 is offline   Reply With Quote
Old 12-06-2018, 01:11 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
The more free-flowing the exhaust is the more likely you are to hear the popping. So, replacing the restrictive factory cats with high-flow cats (or removing the completely, although this is not always street-legal) as well as using high-flow mufflers (or, again, no mufflers) will allow you to hear the pops better.
Apart from this, you can also get the engine tuned to create pops by having the fuel injectors continue to inject for a time after the throttle closes, although this is purely for sound and can actually reduce performance.
KillboyPowerhead is offline   Reply With Quote
Old 12-06-2018, 01:20 PM   #3
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
sell it and buy a v8
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 12-06-2018, 02:04 PM   #4
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
you'll get flamed for that, but you're correct.
Old 12-06-2018, 03:00 PM   #5
SneakySS
OEM? Whats that?
Drives: 2014 Camaro SS Black Widow
Ditto. Ive heard V6’s with headers & pipes. Sounds like a suped up lawn mower. ( only an opinion)
2014 Southern Comfort Black Widow SS LS3
Magnuson Supercharger, ceramic coated ARH headers w/cat deletes, BTR blower cam, Mahle forged pistons, AEM Methanol injection, JRE 8 rib Super tensioner, Innovators West 8 rib serpentine pulley system, Melling high flow oil pump, Lingenfelter high flow fuel pump, McCleod RXT ceramic coated Twin disk clutch, Hooker BlackHeart exhaust. Escort 360 radar detector & dashcam.
Rockford Fosgate 1000w prime amp, 2X12” Rockford P3D2’s
Build and mods done by R&D Motorsports in Baton Rouge
Tune/Dyno done by ,,Engine Power Systems in Baton Rouge
SneakySS is offline   Reply With Quote
Old 12-06-2018, 03:09 PM   #6
WoodBoss
"Old School"
Drives: 2010 2SS L99
Jiffy Pop on the muffler.
WoodBoss is offline   Reply With Quote
Old 12-06-2018, 03:42 PM   #7
redcoats1976
i was thinking rice crispies.having owned a cop calling big block pontiac with duals and headers i feel i can get away with more by being quiet anyway.
Old 12-06-2018, 04:01 PM   #8
splashlog48
splashlog48's Avatar
Drives: 2011 Green SS M6
It’s not an opinion—It’s a Fact !!!!!
Edelbrock EForce Blower, RDP custom grind cam with upgrades,Stainless Power Headers with HighFlow Cats, Stainless Power Retro catback, DSS halfshafts, CAI brand CAI, Tuned ON the Dyno by Steve at RDP. SLP rims,All vinyl stripes removed and painted on, custom hand painted pinstriping, Custom leather seats, Lloyds mats,windows tinted, Sparks emblems, Hurst Billit shifter, and too many small items to list. VDI Scissors doors.
splashlog48 is offline   Reply With Quote
Old 12-06-2018, 05:11 PM   #9
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Here we go
rontammy0 is offline   Reply With Quote
Old 12-06-2018, 05:17 PM   #10
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 12-06-2018, 06:51 PM   #11
Starfall
1bad6
Starfall's Avatar
Drives: 2010 camaro
Not really, if you do a cat delete with straight pipes it sounds like shit, especially without an x pipe, but if you go catless with no resonators and have decent mufflers like the mrt v1 and the xpipe you’ll be just fine, v6’s doesn’t always have to sound like a lawnmower but i have heard some that sound just like honda civics and it really does make me upset to see such a car producing those terrifying noises, be smart about it, and it’ll sound good
Mods: trifecta tune on 93 pump gas, mrt v1 Axle-Back, drilled/slotted rotors, 4" quad tips, Res delete, big worm gfx black out kit all around, interior footwell lights.
Starfall is offline   Reply With Quote
Old 12-06-2018, 09:32 PM   #12
theflea42
#938 of 1524
Drives: 2013 Hot Wheels Edition Camaro
What you need....is a set of glasspacks!
theflea42 is offline   Reply With Quote
Old 12-06-2018, 10:12 PM   #13
1LEJNG
Drives: Red Hot 2014 1LE
crackle Pop
I thought that was the noise V6 guys were trying to stop with new exhaust systems
1LEJNG is offline   Reply With Quote
Old 12-06-2018, 10:47 PM   #14
gringo
gringo's Avatar
Drives: Camaro V6
Stock, the V6 sounds like a little Ferrari. I like it. Keep the old sounding tractor noises for the V8's.
gringo is offline   Reply With Quote
