12-09-2018, 06:46 PM | #1 |
Drives: 2013 camaro zl1 Join Date: Oct 2018
Ls9 cam question
I have a 2014 Zl1 and I am wanting to get some more power out of the car......
I drive it daily so I want a mild cam setup..... My question is with the stock springs and retainers from my LSA would the LS9 cam swap right in, or is it imperative that I change out the springs and retainers? My mods..... 2.38 upper pulley 100mm idler Stock lower ported TB, and Snout.... JBA cat delete ligenfelter CAI ID850 injectors with NGK TR7ix plugs and stock plug wires DSX flex fuel sensor DSX auxiliary fuel pump and tuned..... just on 91 have not done an e85 tune yet car made 540rwhp wanting to get close to 600 as possible before the E85 tune..... is the LS9 cam a good swap or what do you recommend? also what power did you see with your cam setup |
12-09-2018, 07:51 PM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I think you can use the stock springs and retainers. However you will not get close to adding 60 hp... to get to your 600 goal with this cam.
Imo... get a stage 3 cam of your choice, change the springs and retainers and be done with it.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
12-09-2018, 09:47 PM | #3 |
If you’re going to drive it all the time don’t go crazy with the cam profile over a few horsepower. There are a lot of ways to squeeze power but if you’re going to swap cams consider the GT9 over the LS9. The LS9 isn’t going to be enough to do what you want going forward. Any custom cam grinder can get you the best solution based on wbt you have. Don’t bother with the LS9.
12-10-2018, 12:42 PM | #4 | |
I didn't even know ligenfelter made cams. Ive got their intake and pulley so I'll for sure be looking into their cams. Thanks a lot for the info man!! |
12-10-2018, 07:36 PM | #5 |
The LS9 cam is a direct drop-in. You can easily get to 600 with the LS9 cam. I made 600+rwhp easily with the stock 4" pulley on the Whipple (8-9psi).
Granted, there is more power to be had with the GT9, but it's hard to argue with $100 drop-in cam that drives like stock, and pulls all the way to redline. |
12-29-2018, 10:24 PM | #6 | |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
12-30-2018, 10:24 AM | #7 |
Drives: Maggie blown LS3 vette Join Date: Aug 2009
I wouldn't use either. If you made me use one, it would be the LS9 cam. The GT9 cam has stupid high lift and very aggressive ramp rates. There's absolutely no reason to put that kind of stress on your valve train. Add a little duration and back off of the lift. Check with Tooley, Pat G, Cam Motion, or, for that matter, anyone who specs cams. You won't see anyone recommending those hyper aggressive/high lift LSK Comp Cams lobes that the GT9 cam uses.
12-30-2018, 10:50 AM | #8 | |
12-30-2018, 11:35 AM | #9 |
12-30-2018, 12:32 PM | #10 |
12-30-2018, 01:19 PM | #11 |
Here's what Comp Cams ( the folks that manufactured these cams said about this lobe series) ..
The LSK Series has been designed with enhanced characteristics from our latest professional drag racing profiles. These have excellent ramp quickness. They are VERY hard on parts and not generally recommended in street applications! They designed these cams and don't recommend them for the street. There are a jillion other options available that aren't as hard on your valve train. If you're only going to put a few thousand miles on your rig and then sell it, don't worry about it. It will them be someone else's problem. |
01-04-2019, 07:21 AM | #12 |
Dont H8 Me Cuz U Aint Me
Drives: 2016 SS Sedan, 2017 Explorer Sport Join Date: Feb 2010
Hey Tulsa guy! I think you'll reach close to your goal with or without the LS9 cam. First before anything you need to sell those downpipes and throw on some good breathing longtubes of your choice. No smaller than 1 7/8". This will bridge that gap in HP you're seeking. Plus the LSA setups like to breathe. A retune with LT's will significantly bump you. Also when you were on the dyno was it in Tulsa? You may make sure with your tuner that you have enough injector running the 2.38 pulley with E85 even with DSX Aux pump.
Also, is your ported TB an LSA TB or did you switch to an LS3 Style and get that ported? Hopefully i'll see you in "mexico" sometime and we can stretch their legs. :-)
01-04-2019, 10:16 AM | #13 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
If you want some more power but on the mild side (<.600 lift) for dependability go with the Cammotion PD stage 1 - you will need new valve springs but can use beehives....
Grind # XA220/350-XA234/345-18+4 Mild Street Performance Duration at .050: 220/234 118 Lobe Center Angle with a 114 Degree Intake Centerline Lift with 1.7 Rocker Arm Ratio: .595"/.587" Recommended Displacement: 5.3-6.2 Liter Engines Recommended Compression Ratio: 8.5:1-10.0:1 Recommended Headers: 1 3/4" - 1 7/8" Recommended Stall Converter: Stock - 3500 RPM Recommended Rear Axle Ratio: Stock - 3.73 The PD 220/234 positive displacement supercharger LS camshaft is designed for street performance applications in vehicles using 5.3-6.2 liter LS engines equipped with positive-displacement style superchargers. The PD 220/234 Supercharger Camshaft will have a slight performance idle and improved power throughout the RPM range with emphasis on mid-range power and torque. This camshaft can be used in a completely stock vehicle with just a valve spring and pushrod upgrade. Additional performance gains can be appreciated when used with headers, an increased stall speed torque converter, free flowing exhaust and intake systems. Our Supercharger series cams are designed with our renowned smooth cam lobe design that provides quiet valve train operation and excellent upper rpm stability. Cam Motion offers this cam in 5150, 8660 and our top of the line 8620 camshaft cores. You can read more about our cam cores here > Cam Motion's cam cores Recommended Accessories: •Cam Motion .625: Lift Beehive Valve Springs or our .650" lift Dual Valve Spring Kit •Cam Motion 5/16" .080" Wall Hardened Chromoly Pushrods
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
01-04-2019, 05:22 PM | #14 |
With 78K on a GT9 I had better get rid of mine too. It’s been putting a lot of stress on everyone else’s valvetrain for years hahahahahahhaa
