Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Forced Induction
Old 12-09-2018, 08:58 PM   #1
Juiced1
Drives: 2012 2SS CAMARO 45th
DEATSCHWERKS 400L DROP IN FUEL PUMP IN STOCK & ON SALE AT JUICED MOTORSPORTS!
DeatschWerks (DW) is taking it to the next level with the release of a complete fuel pump module solution for 5th gen Camaros - powered by the DW400 fuel pump.
The DW400 5th gen Camaro Module is a complete plug-n-play replacement for the OE unit. The module incorporates the DW400 pump which nearly doubles the flow output of the OE module and increases pressure capabilities to 120psi. This module also integrates seamlessly with the OE wiring harness, level sender, and feed lines. For those wanting a return-style fuel system, the module is easily convertible to -8AN feed and -6AN return. The module also utilizes a venturi fed surge bucket for consistent fueling at low tank levels and high G conditions.
The DW400 module deletes the restrictive OE cardboard fuel filter. A high flow in-line filter is recommended for use in its place. DW has designed a plug-n-play fuel filter kit utilizing their 10m dual stage stainless steel filter cartridge. The DW fuel filter kit is designed specifically for the 2010-15 Camaro with pre-cut -8AN CPE hose terminated in 3/8” EFI quick connects.
  • Complete plug-n-play high flow pump solution
  • Compatible with OE wiring harness, electronics, fuel lines, and level sender
  • Integrated check valve for easy cold starts
  • Flow-optimized internal plumbing
  • Powered by 415LPH DW400 Bosch pump
  • Compatible with pump gas, race fuel, and e85
  • Convertible to -8AN feed and -6AN return
  • Optional filter relocation kit available
Why order this pump? This is a drop in pump set up with no modifications or return line needed. As you can see this pump puts out some serious fuel as well.
Why order from Juiced? Because, with code CAMARO5 you can save some cash and before you order our customer service can recommend the best fuel system for your needs. Want to run E85? Running boost? Give us a call and we can help you out.
DEATSCHWERKS 9-403-7001 DW400 PUMP
Juiced1 is offline   Reply With Quote
Old 01-01-2019, 04:38 PM   #2
Juiced1
If you're adding boost you'll need more fuel
Old 01-18-2019, 10:40 AM   #3
VASTREETRACER
Drives: 2023 Camaro SS 1LE on order
what power levels does this pump support?
2017 Camaro SS 50th anniversary, I sold it but 2010 Camaro SS, whipple, cam, full bolt ons and full exhaust made 739/656 RWHP/TQ on 93 pump gas
VASTREETRACER is offline   Reply With Quote
Old 01-26-2019, 10:14 AM   #4
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
+1...
RealQuick is offline   Reply With Quote
Old 01-26-2019, 06:02 PM   #5
Juiced1
We've had one on a Camaro SS making 650rwhp with no issues. I think it will probably be good up to 700rwhp or so and even more with a bap
Old 01-26-2019, 08:07 PM   #6
RealQuick
Any drop in kits that will support 1000rwhp on 93?
Old 01-27-2019, 09:54 AM   #7
johnnyb305mia
Drives: 2015 Camaro SS 1LE
Check an A1000 Kit. I looked at it as well. Not sure what else is needed to set it all up. As I have not looked fare into it, but it’s drop in according to ther website. I’m sure a return line some fitting and a fuel pump speed control module is needed. Rated at 1k on Ethanol. Because I’ve asked a vendor before
johnnyb305mia is offline   Reply With Quote
deatschwerks, dw400
