![]() Drives: 2021 Camaro 2LT Join Date: Oct 2013
Hotchkis vs ZL1 rear swaybars on V6
The Hotchkis rear 32mm bar uses supplied post type links with a 90 deg
swaybar connection at the top. They are adjustable in length. Mounts in the hole in the control arm close to the caliper. Its unclear to me how the ZL1 bar mounts as I have the LT. However the parts diagrams on GM parts sites show a short link with 2 90 deg connections for all models (LT,SS,ZL1). My LT bar mounts to the inboards "ears" on the arm which uses the link with 2 90 deg connections. What am I missing? I would like to use the ZL1 bar in the rear on my V6, but it is unclear regarding the links if it also mounts to the hole near the caliper like the Hotchkis bar. |
#2 | |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Search threads, I seem to recall there maybe interference with the v6 brakes with some of the bars. The Hotchkis bar is a bit stiffer, maybe like a 30 mm solid on the stiffest hole |
#3 | |
What to do, what to do. Don't want a 32 mm rear bar on my LT as I have a square tire setup. 20x9s and 265/40 20s Last edited by chuckclanton; 12-15-2018 at 12:54 PM. Reason: Error |
#4 | |
OK. Thanks
