Old 12-18-2018, 12:15 PM   #1
Rem
Rem's Avatar
Drives: 2012 1LT Camaro
Battery Tender Hook Up
I see no reason why it wouldn't work, but maybe someone has some insight. With the battery located under the spare tire (2012 1LE), I was wondering if I couldn't Just hook the leads of my battery tender to the boosting locations under the hood. All comments for or against would be greatly appreciated.
Thanks, Rem
Rem is offline   Reply With Quote
Old 12-18-2018, 12:23 PM   #2
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Worked good on mine ,no problems .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 12-18-2018, 03:00 PM   #3
DrLove38
DrLove38's Avatar
Drives: 2013 Black SS/RS
Seems like if you can use them for a jump start it would be OK for a tender.
I hook my tender there.
Someone on here hooked the pigtail up to the posts permanently.
DrLove38 is offline   Reply With Quote
Old 12-18-2018, 03:32 PM   #4
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
I hooked up the tender for my Braille directly to the battery and ran it through one of the grommets right next to the battery so the plug is just behind the bumper. No need to open the hood or trunk, just plug it in when I park it.
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers
AGM 1LE is offline   Reply With Quote
Old 12-18-2018, 03:41 PM   #5
Rem
Rem's Avatar
Lots of good ideas. Thanks for the replies.
Old 12-18-2018, 08:03 PM   #6
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
I’m hooked up in the trunk like AMG did. A number of other people have hooked up to the post in the engine bay and it’s worked fine. If your tender has an indicator light as to the batteries charge level you will know soon enough if you are successful.
HOJO is offline   Reply With Quote
Old 03-20-2019, 10:00 PM   #7
Black 6.2L SS
Black 6.2L SS's Avatar
Drives: 2014 1SS/RS, LS3, NPP
I’m a believer in battery chargers. CTEK is one of the best for reasonable money $70. Check out the new 5.0 model. Walk in Jaguar, Benz, BMW and Aston dealership and you see them plugged into the floor models doing their thing. Just my .02
Hook up on the posts under the hood, route the wires carefully, close the hood, lock the car (for full shutdown mode). CTEK 7 step models can be left on for extended periods of time due to its final low “pulse” step.
https://smartercharger.com/
Black 6.2L SS is offline   Reply With Quote
Old 03-21-2019, 12:57 AM   #8
Blueovalman
Blueovalman's Avatar
Drives: 2012 V6 Camaro 2010 Camaro SS
I have hooked up my battery to the Battery Tender quite a few times and I never had a problem. Only other option would be to remove the battery and take it to your local auto parts store and have your battery charged and tested.
Mr. Clean
Blueovalman is offline   Reply With Quote
Old 03-21-2019, 10:07 PM   #9
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
Always hooked mine up under the hood. Works great.
chef-beavis is offline   Reply With Quote
Old 03-27-2019, 08:53 AM   #10
gringo
gringo's Avatar
Drives: Camaro V6
I did mine at the trunk as well. I have the connector lead going through a rubber grommet under the trunk. You have to bend down near the rear bumper to disconnect it, but I'm still agile.
I guess if you were physically unable to do that, it probably would be best to have it under the hood or somewhere inside the trunk.
gringo is offline   Reply With Quote
Old 04-04-2019, 10:14 AM   #11
TooCool5
TooCool5's Avatar
My auto rundown protect works awesome.
Old 04-04-2019, 04:47 PM   #12
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
http://www.dougshelbyengineering.com/camaro.html
Just installed mine last night really cool kit!
Orange Krush II
Old 04-04-2019, 04:59 PM   #13
gtstorey
Looks like the same thing as what I just put on mine for $14.00
https://www.ebay.com/itm/TecMate-Opt...72.m2749.l2649
I installed mine fairly low on the rear plastic diffuser so it's not real obvious but easy enough to get to.
Old 04-04-2019, 05:43 PM   #14
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
No fuse or battery connection.
Orange Krush II
