Old 12-19-2018, 06:57 PM   #1
Stormcloak
slower than you
Stormcloak's Avatar
Drives: 2012 C6 Z06
Best battery tender
My car will be started less frequently during the winter than I originally thought (maybe 1x per month). Tips or advice on the best battery tender to get for this sort of scenario?
TIA
Stormcloak is offline   Reply With Quote
Old 12-19-2018, 08:47 PM   #2
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
CTEK the best...period
camguynj is offline   Reply With Quote
Old 12-19-2018, 09:02 PM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Everyone will answer with the one and only battery tender they have used.
There are a number of modern battery tenders to choose from, so I would use "you get what you pay for" as your guide.
Rock-It Man is offline   Reply With Quote
Old 12-19-2018, 09:44 PM   #4
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
Been using a Battery Tender Jr. for about 5 years. Cheap and works well.
qcman is offline   Reply With Quote
Old 12-19-2018, 11:13 PM   #5
Welker2
Ret AF, cancer survivor
Welker2's Avatar
There are a lot of very good tenders/maintainers on the market today. I personally like and use Deltran Battery Tenders. They have a great reputation, are very reasonably priced and can be purchased at just about any auto parts store or from any number of on-line sources. Have used a Battery Tender Plus on my Corvette for years and it has worked great. Recently replaced it with a Battery Tender 800 and the Plus will now be used on the Camaro when we take long trips in our CUV.
Old 12-20-2018, 12:28 AM   #6
PJMZL1
PJMZL1's Avatar
Drives: 2015 ZL1
Ctek FTW
2015 ZL1 M6
PJMZL1 is offline   Reply With Quote
Old 12-20-2018, 09:02 AM   #7
Memphis SS
Memphis SS's Avatar
Drives: 2017 SS A8 Hyper Blue/White Stripes
As a few have posted above there are several good ones on the market.
I've used Battery Butler for about 15 years or more and works great if that's any help to you.
https://www.lectriclimited.com/battery-butler-products/
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD
Memphis SS is offline   Reply With Quote
Old 12-20-2018, 09:11 AM   #8
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
I've been using Deltran Battery Tenders for 11 years without fail. I still have my first unit I bought a decade ago.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
'25 Silverado 1500 High Country 6.2L
lbls1 is offline   Reply With Quote
Old 12-20-2018, 09:32 AM   #9
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
TIA
What you should do is ignore everyone`s opinion because the battery maintainer they have and use is the "best" for you. Just Google (battery maintainer reviews) or what ever search engine you use and draw your own conclusion as to what is best for you.
Free Trade is not Fair Trade
I am, we are INDIVISIBLE
Invictus, By William Ernest Henley
mickss is offline   Reply With Quote
Old 12-20-2018, 08:49 PM   #10
SecondZ28
SecondZ28's Avatar
Drives: 2013 ZL1
x2
I use 3-4 of these at any given time. Never had an issue.
'13 ZL1
'06 TBSS
'98 TJ
'87 GN
SecondZ28 is offline   Reply With Quote
Old 12-24-2018, 11:18 AM   #11
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
I am thinking about getting one. How are you guys hooking it up. I was just planning on using the charging post but what do you do with the power cord? Just close the hood on it since there seems to be a good space or fish it thru thru grill?
JD555 is offline   Reply With Quote
Old 12-24-2018, 11:42 AM   #12
PJMZL1
PJMZL1's Avatar
Drives: 2015 ZL1
Fish it thru from the floor and close the hood.
2015 ZL1 M6
Old 12-24-2018, 01:29 PM   #13
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
Many of these have a good quick disconnect. Be careful if you switch brands because some fit the plug but have the polarity + - reversed.
I like the bat tender jr for price and performance and a black and decker. I think there were some fake "bat tenders"out there for some time that caused overcharge or burned out. The idea is they charge then "float" and don't constantly charge the battery if not needed. Reading much more; even the float charge might shorten the life of the battery if left on 24 7 for years. I try to plug it in and unplug it from time to time. How long it needs to be plugged in depends on how big drain you have. Batteries have internal discharge and slowly die even disconnected, that takes maybe 6mo to a year. Computers and clocks draw some power, and car alarms much more. Some other accessories like powered amps might cause a drain if they weren't properly engineered. Ideally a few days on and a few weeks off would be best for the battery with a low power unit that has float. As you know completely discharging a lead acid battery drastically shortens its lifespan (better to float charge it 24/7 than have that happen).
silversleeper is offline   Reply With Quote
Old 12-24-2018, 10:35 PM   #14
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Yes, there is a good size opening on the passenger side. The tender can sit on a stock air box.
BTW, always disconnect the tender before starting the Camaro. The alternator can create a spike that may damage it.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
