EXTREMZ
Drives: 2015 Z/28 #891, 2012 2SS 45th Anni Join Date: Jul 2012
Blown differential at 20K miles
With about 35 track days on my Z, I noticed a whining sound coming from the differential. After another couple of track days, the whining grew louder, then a leak developed in the line from the diff cooler to the pumpkin.
Took it to the dealer since it was under warranty. Upon opening the pumpkin a huge amount of metal slivers dumped out. The bearings were galled something wicked. Dealer put in new diff under warranty. I was in the habit of changing the gear oil every 3 track days. Guess I'll be changing it more frequently going forward. I was using Amsoil Severe Duty 75-90W with 2 ounces of friction modifier. Car now has the OEM gear oil, which supposedly has the friction modifier in it.
ARH long tube headers, no cats
Comp Cams stage 2 custom grind Ported throttle body JPSS Oil cooler JPSS SAI plates JPSS Rear sway bar Forza Continenti exhaust controller ZL1 Add-ons wickerbill Brey-Krause Harness bar Schroth 4 pt. ASM harnesses Auto-blip |
![]() Drives: 2014 z28 Join Date: Oct 2018
So I was under the impression the friction modifier was for clutch type limited slip differentials? Being our cars have Torsen diffs, it’s only gears no clutches, so why the need for the friction modifier? Hoping to learn something here.
If you did 4, 20 min sessions every track day, that’s roughly 46 hours of track time. If your only failure was the diff, id say that’s fantastic! How has the car performed so far? Any other issues ? Last edited by MX621; 12-22-2018 at 07:41 AM. |
EXTREMZ
You're right about no clutches in the diff. Maybe the AC Delco gear oil will help.
The car has been otherwise flawless. A very stout vehicle.
![]() ![]() Drives: 2015 Z/28 #0058 Join Date: Apr 2018
Track prep document says to change rear fluid after every track event
https://www.camaro5.com/forums/attac...6&d=1493920184
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's - '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony Sold: - '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's https://www.instagram.com/__jon__athan__/ |
EXTREMZ
Yup, shoulda, woulda, coulda...
#6 |
![]() ![]() ![]() ![]() Drives: 2020 ZL1 1LE Join Date: Sep 2012
I would change the fluid quickly after the diff change as some of the metal shavings could have gotten into the cooler lines and flushed into the new diff.
For my rebuilt TrueTrac diff, the builder strictly uses Lucas 85w-140.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
#7 |
'It's an experiment'
Torsion diffs don’t need the limited slip additive usually, you don’t want them to slip really — Interesting the service manual calls for that (track prep)...
I have a torsional diff (TrueTrac) and it specially says no limited slip additive... Maybe GM’s is different... -Don
747 RWHP 794 RWTQ
#8 |
EXTREMZ
New cooler lines were put in. Nevertheless, l'll be changing out the new fluid at 500 miles if not sooner.
#9 |
![]() Drives: 2014 Z/28 # 89, 69 Camaro, 2013 ZL1 Join Date: Jul 2013
Not seen many rear diff failures on this forum ? maybe using non GM fluid and not changing after every track day resulted in the premature failure ?
#10 |
Coolant lines are seperate from diff fluid, there's a small radiator attached to the rear cover and circulates trans fluid not gear oil.
Orange Krush II
#11 | |
![]() Drives: '15 Z/28 Join Date: Jun 2016
Also, to those who do multiple events on their fluids... what does every race team do following a race weekend? GM has outlined the proper procedure... I realize some folks smoke and others don't floss their teeth which is why YMMV. ![]() Lord knows enough issues happen when we track WITH proper maintenance. |
#12 |
Toy Collector
Just curious, but how much does it cost you each time to track your car? Understanding you may do all the maintenance work yourself.
#13 | |
I consider my time part of the entire enjoyment of tracking as a hobby. As for the cost for an entire track weekend... please don't ask. Three days at Watkins in the Corvette including "absolutely everything" ran north of 2k with ease. I really don't want to sit and figure it out... and I certainly wouldn't want my wife to know. Also -- this is for HPDE and not a real "race" weekend. It just goes north from there...
#14 | |
![]() Drives: 2012 BMW 135i Join Date: Nov 2016
Awhile back I posted up some maths on the subject if you want to search for it which included reserves for CCBs - I recall 1500/day when you add pads, fluids, CCBs (front and rear), tires, insurance, HPDE fees and insurance. Instructing, buying used tires tires, selectively buying insurance based on the day's goals and steel brakes have driven down the full cost estimate pretty well. |
