Throttle Junkie
Drives: 2015 Camaro 2SS Join Date: Dec 2016
Tire size problem
I got the mrr replica rims from phastek. 315/35 20 on 20x11 rims on back and 285/30 20 on 20x10 on the front.
Test drive it and get power steering, abs, and all kinds of warnings to service. Not to mention every time I hit the brakes over 30mph I could feel the abs kicking in until all the warnings. While the warnings were on I got reduced power steering and prolly no abs or stabilitrak. I realize after buying the rubber that I messed up on the front tire size. Should have gotten 35 aspect ratio. So now the computer is lost in translation and puking up errors What are my options? Not sure if I can return the rubber...
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Pull fuses 40 & 43 to disable the nannys until you can figure out a solution. It also disables power steering.
![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Join Date: Jun 2016
Sell the 30's and get 35's...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
Throttle Junkie
IIRC, stock sizes are (F/R) 245/45/20 & 275/40/20. Those equate to a tire size of 28.68 & 28.66 inches respectively. Your new sizes, 315/35/20 & 285/35/20 equate to 28.66 & 26.73 inches respectively. It is the approximate 1" difference in tire height that is causing all of your issues. You can run the stock rear size up front without any issues. MY current setup is a 315/35/20 & 275/45/20 and I have ZERO issues.
Hope this helps. -Scott |
#6 | |
Scott's45
Drives: 2012 2SS 45th Anniversary Join Date: Mar 2012
i was about to say the exact same thing. i also run 315 & 275, no issues. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
#8 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Even 285/35 could be pushing it once you consider tire wear not being equal front vs rear and replacing the rears only. Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
#9 |
#10 |
285/40 calculates out to a tire that is 28.98" tall, about 1/3" taller than either the 275/40 or 315/35. I don't know where the limit is for the computer, as far it not losing it's mind over the tire size difference.
#11 |
3% is the number I've heard the most reliably.
Doesn't mean there couldn't be a little more tolerance, but it doesn't mean that there is either. Norm
#12 |
Throttle Junkie
So, what i am not hearing is that the dealer can reprogram, or update my ecu to accept the new sizes. I think the ZL1 has over 1" difference between the fronts and rears... so maybe there is something a dealer can do????
It looks bad ass with the tires on it now.. i want to keep it this way Theres gotta be something I can do. |
#13 | ||
27.9" front, 28.4" rear . . . only half an inch. https://www.tirerack.com/tires/tires...oModClar=Coupe Quote:
The only way I can think of where you *might* be able to get it to work involves a fair amount of machine shop work where you'd have to be able to describe exactly what you need him to do. He'd be starting from fresh chunks of iron or steel. So I guess your choice is between having a car you actually enjoy driving and doesn't get in your way of enjoying it . . . or a car that satisfies your appearance preferences but is basically worthless for anything other than its value as an expensive driveway ornament. Norm
#14 |
Nope, no feature in HP Tuners for changing tire sizes. Go get some 275/40/20's, or drop down to a 19" wheel in the front.....I'm sure you could sell those 285's fairly quickly in the classified section/craigslist.
-Scott |
