Old 12-24-2018, 09:22 AM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
Forged Pistons and Rods
I'm at the point where I'm going to have to stiffen up the bottom end. Well, maybe I'm past it.
I'm looking at forged pistons and rods, and plan to reuse the stock crank. My goal is a street-able 900-950whp. I've never been to the track, but do plan on going occasionally.
I have a couple concerns.
1.Regarding the different rod lengths, 6.125 and 6.098. I assume that I can only use a 6.125 rod with a piston designed for it. Same with the stock rod length 6.098, must use a piston designed for it. But both will result in the same total length, correct?
2.Also, about compression. I'm running a centri blower and will probably be dropping a few pulley sizes, and increasing boost. What is the ideal compression ratio?
3. What cc is the stock ls3 head?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 12-24-2018, 11:05 AM   #2
TheInfamouSS
@LS.ACE
TheInfamouSS's Avatar
Drives: 2014 Chevy Camaro 2SS/1LE
1. One thing I learned is ALWAYS just measure for push rods. It's always better to double check and make sure you get the right ones.
2. I will be around the 9.x:1 compression ratio with my forged pistons and rods with stock heads.
3) 68.5 cc .
Some weird snail with a belt on it | Tial Q Bov | CCP Jam Cam | Stainless Works 1 7/8" Headers to Custom 3" Exhaust | Alky Control Dual Nozzle| ProMeth Trunk Mount Tank | Melling Oil Pump | DSX Aux Pump | id1050x Injectors | McLeod RXT w/ Monster Billet Release Bearing | ZL1 3.73 Rear Diff | BMR Delrin/Poly Diff Bushings | DSS 1-Piece Aluminum Driveshaft | ZL1 Axles | Metco Driveshaft Loop | BMR Adjustable LCA's, TA's, Toe Rods | BMR Adjustable Sway Bar w/ Fe3 End Links | Mickey Thompson 305/35-20 Street S/S Drag Radials |
TheInfamouSS is offline   Reply With Quote
Old 12-24-2018, 11:14 AM   #3
eLeSthree
3) 68.5 cc .
What CC piston did you chose?
1158whp 1017wtq.
630whp 658wtq
Old 12-24-2018, 11:58 AM   #4
DSMer1
Drives: 14 and 15 SS's
1. Yes, use a piston with the pin height designed for the length rod you are using. They end up being the same overall length.
2. What fuel are you using? I'm building a motor right now and am right about 10:1 with high airflow but I always run pump E at the minimum.
3. As stated, about 68cc on virgin heads
What block are you planning on using? If you are truly planning on being at or above 900whp, the factory aluminum block should be looked at. Although it will take it for a little while, the factory aluminum block will not survive a long time at those power levels.
I know Joe blow and his cousin and his neighbors friend have all done it and it has been 'fine', hell I've been there. The fact is the stock aluminum block will not stay true long at those power levels.
TSP has a very affordable option for sleeving the aluminum blocks, $2300 for a brand new block sleeved to start and I think they will sleeve your existing block as well.
There is always the choose of iron as well.
I was just faced with this problem. My logic was saying 'but I've been making xxx power on a bone stock long block for a long time'. The fact is the stock aluminum block is just barley holding on
It sounds like some bigger power is in your future, I'll look forward to hearing about it!
Bolt-ons!
DSMer1 is offline   Reply With Quote
Old 12-24-2018, 12:22 PM   #5
TheInfamouSS
@LS.ACE
I went with -11cc pistons. I am going to Private Message you now.
Old 12-24-2018, 02:50 PM   #6
eLeSthree
The pump E here is about 70%, and easy to get, so I'll continue to run that.
I'm trying to price out the cost of a piston/rod upgrade compared to the TSP 6.0 gen4 iron shortblock. With TSP rods/crank and weisco pistons, with arp main studs and rod bolts its about $4800.
Just the piston/rods might cost me half that after machine shop costs and then having the car apart for much longer... Might have to bite the bullet and get the short block.
1158whp 1017wtq.
630whp 658wtq
Old 02-09-2020, 04:37 PM   #7
Big Biscuits
Big Biscuits's Avatar
Drives: 2010 1SS LS3
To bring this back up as I am going to build a standby engine just in case. I found a stock LY6 with 100k miles local and I am gonna build a stroker out of it. Truck burnt, but the short block and heads are fine. $500 pull out. Can’t beat that. Should be able to go .005 over with a hone and block check from the machine shop. Tsp and K1 stuff seems to hold up. We shall see.
2010 CGM 1SS
408/4L80E/ZL1
Vortech V-13 94C
Big Biscuits is offline   Reply With Quote
Old 02-09-2020, 05:09 PM   #8
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I started looking into this as well for future. I'm thinking I found forged 416 short blocks for 5kish i'm thinking its worth it to go that route as i might go TT if i blow this up and push for around 1khp. I just barely started looking at this though i haven't done a lot of research yet.
Greenhornet2 is offline   Reply With Quote
