Old 12-29-2018, 10:57 PM   #1
TulsaZL1
Drives: 2013 camaro zl1
A10 in a 5th Gen?
Has anyone done this swap yet?
I am curious for down the road........ I love the gearing in the newer ones, my A6 only has 33K miles on it.....
I am just curious if anyone has looked into this or has anyone successfuly swapped an A10 into a 5th gen Zl1
TulsaZL1 is offline   Reply With Quote
Old 12-29-2018, 11:18 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
A few issues. Will an LT based trans bolt up to a LS engine? How will the TCM integrate with the LS system?
Vegas Bound is offline   Reply With Quote
Old 12-29-2018, 11:58 PM   #3
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
I’d think if it could bolt up you’d likely have to go stand alone to get everything to communicate
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 12-30-2018, 12:22 AM   #4
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
If it’s possible I am definitely interested!
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 12-30-2018, 01:00 PM   #5
Splat
Splat's Avatar
Drives: 2012 1SS M6 IOM
I dont see why not.
The new RST Tahoe somes with the new 10L80 10-speed automatic, and its backed up with our LS3.
https://www.caranddriver.com/reviews...wd-test-review
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI
Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018.
Splat is offline   Reply With Quote
Old 12-30-2018, 02:13 PM   #6
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I would seriously consider this if possible.
MODS:
Old 12-30-2018, 05:48 PM   #7
DSMer1
Drives: 14 and 15 SS's
Originally Posted by Splat View Post
I dont see why not.
I'm not saying it is or is not possible but just to clarify the RST Tahoe does NOT have a LS3. That would be a version of the LT1, new generation direct injected. Ya know, the generation that includes the new ten speed.
Bolt-ons!
DSMer1 is offline   Reply With Quote
Old 12-30-2018, 07:06 PM   #8
Vegas Bound
My concern would be how the trans and engine line up and bell housing bolt pattern. Are they the same, are they different? I don't know. Hence, my original comment.
Old 12-31-2018, 06:10 AM   #9
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
The hardest part will be communicating with the CAN bus... There are at least two threads on this.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 07-14-2020, 07:59 PM   #10
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Dang still no updates on this subject
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 10-09-2022, 03:01 PM   #11
DomSS
Dom251
Drives: Chevy camaro SS
No update yet? Awwww
DomSS is offline   Reply With Quote
Old 10-21-2022, 12:32 PM   #12
Little Walter
Drives: ZL1
You might check with Andy at Livernois, they stay at the for front on a lot of stuff like this.
Little Walter is offline   Reply With Quote
Old 10-22-2022, 08:08 AM   #13
JANNETTYRACING
JANNETTYRACING's Avatar
I have an A10 crate trans in stock along with the controller package I will pull the instructions and see if there is anything in there about mating to an E-38 or E67
Yes they bolt up but it is a bigger trans so I don't know how it would fit in the tunnel.
Obviously shorter driveshaft and fabricated trans mount.
Bad news guys
THIS TRANSMISSION SHOULD NOT BE USED AS A SERVICE REPLACEMENT TRANSMISSION FOR ANY PRODUCTION VEHICLE. THIS TRANSMISSION IS
FOR A CHEVROLET PERFORMANCE "LT" STYLE CRATE ENGINE USING A CHEVROLET PERFORMANCE ENGINE CONTROL SYSTEM. IT WILL NOT
FUNCTION WITH A "LS" STYLE ENGINE CONTROL SYSTEM, NOR ATTACH CORRECTLY TO ANY ENGINE EXCEPT AN "LT" STYLE. EACH CONTROLLER IS
MATCHED TO THE TRANSMISSION AND NOT INTERCHANGEABLE WITH ANOTHER TRANSMISSION. EACH SOLENOID WITHIN THE TRANSMISSION IS
CHARACTERISED AND THAT INFORMATION IS LOADED IN TO THE CONTROLLER.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 10-26-2022, 01:30 AM   #14
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
Hey Ted, is there any EFI systems on the market that can control a 10 speed in general other than from GM?
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported 821 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, DSX aux pump, zl1 in tank. deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
