Old 12-31-2018, 12:20 PM   #1
shan1997
shan1997's Avatar
Drives: 2013 Red Hot Camaro
What could be wrong
My lock on The inside of the door is not working.
I had my brakes worked on recently and noticed it after
I picked my car up but would replacing brakes and rotars
Affect the locks on the inside of my car? I can use my key fob
To lock and unlock the doors as the trunk but the switch on
The inside of the car on the driver side won’t respond. Is it
Something electrical? What could be wrong? Thanks in advance
shan1997 is offline   Reply With Quote
Old 12-31-2018, 12:53 PM   #2
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Electrical switch failed? Take it off. Spray contact cleaner try again. Replace switch
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 12-31-2018, 01:06 PM   #3
gringo
gringo's Avatar
Drives: Camaro V6
Take it back and tell them the door lock switch worked before you brought it in. However, if you feel uncomfortable with them tearing apart your door panel, just take it off yourself and repair/replace the door lock switch.
gringo is offline   Reply With Quote
Old 01-01-2019, 01:25 AM   #4
rshelar
rshelar's Avatar
Drives: 2017 1SS auto vert Nightfall Gray
Just had the same problem with rear doors on my 2004 Chevy crew cab. Actuators had to be replaced. Unfortunately, my son didn’t know that the doors weren’t locking until some POS stole his backpack with his text books. Bastard!
rshelar is offline   Reply With Quote
Old 01-01-2019, 03:43 PM   #5
shan1997
shan1997's Avatar
Thanks
Old 01-01-2019, 03:44 PM   #6
shan1997
shan1997's Avatar
Thank you
Old 01-01-2019, 03:45 PM   #7
shan1997
shan1997's Avatar
Thanks
Old 01-01-2019, 04:33 PM   #8
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
Sounds like a switch and it is just a coincidence that you had brake work done and noticed it. I would just replace the switch, I can't imagine it's that expensive but I would also never guess the third brake light is $200 either so who knows.
Talladega is offline   Reply With Quote
Old 01-01-2019, 08:07 PM   #9
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
check your fuses first if there is one for the door switch. that would a easy first check. if you need a electrical trouble tree for the door locks I have access to service information
2012 zl1 stock 7000 miles
2010
TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems.
Edit Signature
lionssfan is offline   Reply With Quote
Old 01-01-2019, 09:11 PM   #10
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
If the lock works with the remote then it can't be the actuator or a fuse.
At least you can pull the handle once to unlock, and again to open.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 01-01-2019, 09:21 PM   #11
chris41
Drives: 2011 Camaro SS convertible
I have a brand new door lock switch that I never installed if you think you have a bad switch. Just PM me your address.
chris41 is offline   Reply With Quote
Old 01-02-2019, 07:00 AM   #12
Dogmeat
Dogmeat's Avatar
Drives: 2011 RS
Hey lionssfan…..
Not meaning to hijack this phrase, or to be a smartazz at all, but I just noticed that on your avatar you have STOLE spelled as STOLED.....Jut FWIW!!
Proud Owner Of '11 Camaro
Dogmeat is offline   Reply With Quote
