High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
'07-'09 ZO6 wheels and tires fit?
Question is: Can I put a set of '07-'09 Corvette ZO6 wheels and tires on my
2SS? Will they direct fit or are they too wide in the rear? The ZO6 sizes are as follows: Fronts- 18X9.5" with 275/35ZR18 tires............Rears- 19X12" with 325/30ZR19 tires I can buy chrome OEM ZO6 rims cheap from someone I know and a set of 4 tires only runs about $750 from tire rack. Please, no speculators. Only answer if you know for sure or have tried this combination.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
![]() Drives: DD- 15' Chevy SS Sedan Join Date: Oct 2009
i doubt youll find someone that has actually installed them. but if your really that curious and no one posts that they have, ill be happy to slap my stock set on there and take a pic for you sometime this week, i gotta balance my wheels/tires anyways
but FWIW, judging by the width and offset, they will stick out, if they dont get slammed into something on the back side, the back spacing is crazy on the rear wheel. its over 12" wide with tire with a high high offset. BUT thats speculation, youve got me curious now so lets see. but my moneys on no
![]() Drives: 2010 equinox looking@Camaro Join Date: Nov 2009
bolt pattern for the regular corvette/ gen4 camaro is 120.7 not 120.0 or 4.75 not 4.73 they will fit on but the bore center is also different 70 something not 67.1 like the camaro. Now this may be all different for the ZO6 I don't know. Guess i'm a speculator but something to think about.
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Your rears will not fit the car as it is set up now, You will take out the tire as you know this car has a independent rear.
There is 100 mm spacing from the rotor mounting point to the inside of the lip and 235 mm spacing from the rotor mounting point to the rear inner fender, that is a total of 335 so that is 13"+ but the tire and rim need room to move and that is to close. ( don't forget that a 12" rim is at least a 12.5 on the out side ) The offset is close and with a small spacer of 6mm it will work as this is what i am doing now with some 3pc wheels, The best offset for the car are as follow, 20X10.5 W/ 2.5” OUTER/8” INNER = ET+43mm offset (CURRENTLY YOUR FRONT SETUP) 20X11.5 W/ 2.5” OUTER/9” INNER = ET+56mm offset 20X12 W/ 2.5" OUTER/9.5” INNER = ET+62mm offset You my friend need to do a min tub to fit it on the car if you want to run a 12" rim on a gen5 camaro. Last edited by 2SSRS@Gen5diy; 12-01-2009 at 11:02 AM. |
![]() ![]() Drives: Corvette ZO6 CSR edition #47 Join Date: Apr 2009
So based on whats been said is the fronts from a C6 Z06 will work in the rear of a Gen 5 camaro? (20x10.5)
Nationwide Turf
"artificial turf factory" |
#6 |
#7 |
yeah the C6 Z06 runs 18x9.5 frnt 19x12 rear.
![]() btw just because the car is "independent" rear doesnt mean anything.... last time i looked the vette didnt have a rigid axle
#8 |
NOICE!!! ™
Tried it wont fit without a spacer on the rear. Not going to do it cause it wont fit flush with the hub, I'm not taking any chances
#9 | |
#10 |
Did you look at the hotchkis video of the movement of the rear tire, You need more room to the inner fender.
#11 |
#12 |
Resident Engineer
Drives: 2010 Camaro SS, 1988 GMC S-15 Join Date: Jun 2009
ok, so forget the rears....will fronts fit on both front and rear of the car?
![]() 12.68 @ 109: LSR cai, Borla S-type axle-back, Tunes |
#13 |
![]() Drives: 2008 Redline, 2004 Dale Jr MC Join Date: Mar 2009
Roll your fenders
If you have the oysters to do it though. Not sure if I would.
#14 |
| FS 20" Midnight Silver RS wheels and tires | jsharp | Wheels / Tires | 24 | 12-14-2009 12:19 PM |
| 2010 CAMARO SS 20 POLISHED WHEELS & TIRES 1,800 or Best offer | comptect | Wheels / Tires | 11 | 07-23-2009 01:33 AM |
