01-10-2019, 04:23 PM | #1 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2018
Brake Fluid Amount
I've dug around on here for awhile and I keep seeing different amounts from some people (unless I am reading incorrectly) so I'm going to come right out and ask.
I am getting my brake fluid changed in my 2018 SS 1LE for some up coming track days and want to know how much brake fluid to get. The most common answer I found is 1 liter so I bought three 500ml bottles of Motul RBF 660 so that gives me 1 liter and a half to work with but that will that be enough to get through a full brake flush/refill
2018 Camaro 1SS 1LE
01-10-2019, 04:28 PM | #2 |
Drives: 2016 1ss camaro Join Date: Feb 2016
i was told a 2 big bottles of castrol srf is enough and you will have like 4/5 of the second bottle left lol
01-10-2019, 05:45 PM | #3 |
That should be 2 liters then from what I am seeing
2018 Camaro 1SS 1LE
01-10-2019, 06:26 PM | #4 |
well my buddy said since i gotta get mine flushed 1 liter for a full system and another one just in case so you should be good
i used motul 600 a few years ago but was told the castrol stuff is better so gonna flush and refill with that this month
01-10-2019, 07:47 PM | #5 |
Drives: '18 1SS 1LE Join Date: Sep 2017
The BG brake fluid exchange machine at work uses a 2qt jug.
'18 1SS 1LE Black, PDR
01-11-2019, 08:45 AM | #6 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Every time I do mine I end up only needing 0.9L for a thorough flush with my Motive bleeder. If you're not paying attention to when the old fluid is done purging through each bleeder then you'll use more.
2017 "M1SS1LE" in Hyper Blue w/PDR
01-11-2019, 10:20 AM | #7 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I can also do the full car in a little less than 1 L doing the pedal apply method.
Use the clearest line you can on the caliper to make it easier to see the fluid color change. Can also use a syringe to get as much old fluid out of the reservoir before adding the new fluid to make the fluid color change less blended.
2017 SS 1LE.
01-11-2019, 10:45 AM | #8 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Flushing fresh fluid with expensive fresh is such a headache
I make sure I have 2L to ensure it's all out |
01-11-2019, 11:19 AM | #9 |
Awesome, thank you all, I made sure I got 2 liters of Motul RBF 660 on the way. I did see where Castrol SPF seemed to be another high choice as well so depending how I like the Motul's, I'll switch to Castrol.
I am looking at maybe doing 3 track days inside of 35 days so the brakes are going to get a workout for sure
2018 Camaro 1SS 1LE
12-20-2023, 02:50 PM | #10 |
Thanks for this tip! I know it's 4 years later, but a great idea as I will be tackling this job soon.
2020 Camaro 2SS - Riverside Blue, NPP, Magnetic Ride, Sunroof
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
12-21-2023, 12:30 PM | #11 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
