Old 01-16-2019, 11:35 AM   #1
jethrobandit
jethrobandit's Avatar
Drives: 2013 Black 2SS
Need Help with Bushings
I've got a 5 stage upgrade plan I've been working on for some time, but I'm stuck on bushings. I'm trying to stage similar suspension upgrades at the same time so the work is more efficient and not taking things apart multiple times. I'm also trying to save SOME money, which is proving difficult.
Suspension upgrades are a rabbit hole of research and I've learned a lot over the last few months. But, without actually going through any installs or having anyone to bounce this stuff off of, I'm having a hard time coming to final decisions. For instance, I don't think I need the BMR FULL bushing kit (BK031), if I am doing the following:
  • BMR Adjustable Toe Rods TR003
  • BMR Trailing Arms TCA033
  • BMR Lower Control Arms TCA028
  • 1" BMR Lowering Springs
Wasn't planning on lowering in this stage, but buying the springs and the non-adjustable control arms for lowered cars were cheaper than the adjustable control arms.
With those pieces, I thought there would be too much overlap getting the full bushing kit??
Can I get away with just doing the subframe/cradle bushings or do I need to add others associated with the above parts?
Thought I would save the differential bushings for stage 2 with sway bars (not really related) and such or stage 3 with the new gears and TrueTrac.
This is a street/strip car and I'm trying to build this into a monster... the right way. I want it to be strong and stiff... but not too stiff. Just trying to better plant the power I'm making on the drag radials before I start upping the power again.
jethrobandit is offline   Reply With Quote
Old 01-16-2019, 12:03 PM   #2
bkevind
bkevind's Avatar
Drives: 2013 2SS RS 1LE
Having recently done solid cradle bushings and poly/delrin BMR diff bushings - a word of warning: whatever noise your diff makes will be dramatically amplified.
I also have the LPW diff cover, which makes my car have the trifecta of amplified diff noise.
And my yukon r&p are unfortunately rather noisy. If I had to drive this thing on the street much (like daily commuting) I'd rip out the yukons, and change diff mounts to something quieter at a minimum, and if the noise was still too much, change the solid cradle to something quieter.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR
CTSV/ZL1 front calipers/rotors + G-Loc
Forgestar CF-5 19x11
bkevind is offline   Reply With Quote
Old 01-16-2019, 09:12 PM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Don't forget to get a set of Z28 upper control arm bushings.
Orange Krush II
olblue75 is online now   Reply With Quote
Old 01-16-2019, 09:13 PM   #4
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
Your parts list looks good to me. I have a very similar set-up in the rear, but I'm at stock ride height. I saved money by getting the non-adjustable toe rods, but you might need the extra adjustment after lowering the car. If you don't, then don't waste the money.
The kit you listed has a bunch of stuff in it. I imagine that there is going to be some overlap.
I think you are fine doing just the cradle bushings for now, but you will want to add the diff bushings eventually.
I also did the rear upper control arm bushings, but I ordered those by mistake and figured what the heck.
Your build plans look very solid to me. I'll look forward to seeing the build progress.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 01-18-2019, 10:07 AM   #5
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
I agree with all this. Looks solid to a start of keeping the back wheels planted. I noticed, in a very good way, once I upgraded the cradle bushing.
Old 01-18-2019, 12:30 PM   #6
jethrobandit
Yeah I had the subframe/cradle bushings as a required update with these other 4 items. I didn't really want to do the differential bushings at this point due to inexperience and fear (I have to take apart and support... what??? Ha!). But, also because I knew those were basically independent of the stuff I was disassembling for those 4 parts.
So, I guess the question I really need answered is are there bushings for the other end of the trailing and control arms that don't come with them that I should be getting too? Or considering what I'm taking apart, am I missing an opportunity to replace a particular bushing as I reassemble everything? Would just hate to be putting stuff back together and go "CRAP, I need to order some of those!"
Thanks All!
Old 01-20-2019, 09:06 PM   #7
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Upper control arm bushings, steering rack bushing, front radius arm inserts.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 01-20-2019, 11:41 PM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Radius arm bushings are huge for the front end, steering seems more precise.
Orange Krush II
bushing, control arms, lowering, suspension, trailing arm
