Old 01-17-2019, 06:36 AM   #1
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
BTR stage 3 blower cam excessive exhaust smell
Just wondering if others have noticed raw or excessive fuel smell after installing this cam. I know this cam has some blow by because when the intake is opening the exhaust is not fully closed. I'm wondering if this is the reason for the excessive exhaust smell. or could it be the tune my tuner gave me. thanks. I still love this cam regardless. I want to get rid of the cats but the smell will get worse.
2012 zl1 stock 7000 miles
2010
TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems.
Edit Signature
lionssfan is offline   Reply With Quote
Old 01-17-2019, 08:13 AM   #2
QUICRNU
Drives: Z06 wannabe
Ive not really met a cammed car that didnt smell like exhaust. I have the BTR PD Blower 3 cam as well and it smells less like fuel, more like burnt fuel. Do you moitor with an AFR gauge? Rich settings could be the culprit aka tune
Apex Focused
QUICRNU is offline   Reply With Quote
Old 01-17-2019, 12:22 PM   #3
arussh
arussh's Avatar
Drives: 2011 2ss/rs, 1990 iroc-z
check ur tune first if not too rich then add a second set of cats to your exhaust will help alot.
2011 2SS/RS 6.4 sleeved ls7, ported CTSV supercharger; zl1 hat,fuel pump with Kenny Bell boosta pump,102 throttle body,6l90e g-force driveshaft,zl1 rearend and axels, ID 850s, dual pass heat exchanger; Auto Tech electric water pump;160 degree themostat; ls7 pushrods,rockers; Metco polished pulley kit, 2.4ud; ls3 assessory bracket kit;2 Hayes trans coolers; CAI intake; Texas Speed 1 7/8 headers; 3" Magnaflow exhaust; Alkycontrol meth kit; p;Elite catch can; BMR 1" lowering springs,
ZL1 10" front 11" rear rims, trans and engine tune by wally a.
arussh is offline   Reply With Quote
Old 01-17-2019, 12:33 PM   #4
lionssfan
lionssfan's Avatar
no I dont monitor A/f ratio, but I'm in the process in getting a aerometer gauge. I think it's more like burnt fuel yes. irratates my eyes and noise alittle.
2010
Edit Signature
Old 01-17-2019, 12:41 PM   #5
lionssfan
lionssfan's Avatar
never heard that two cats. I worry about these cats coming apart anyway. i know they can do some damage to the engine. well I will be getting a new tune because of upgrades. and I'll be working with a new tuner.
2010
Edit Signature
Old 01-17-2019, 12:48 PM   #6
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
where are you located in Michigan? If you are in metro detroit...use Dr Phil to tune it....he is the best LS tuner in the area
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 01-17-2019, 12:51 PM   #7
lionssfan
lionssfan's Avatar
I've heard of him. he's hard to track down. I tried on my last tune to locate him. thanks
2010
Edit Signature
Old 01-17-2019, 12:51 PM   #8
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
EOIT...…. needs to be tuned.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 01-17-2019, 12:55 PM   #9
gm2376
gm2376's Avatar
he rarely does a private appointment, but he tunes for a lot of shops. Call Katech. He is their tuner.
Old 01-17-2019, 12:58 PM   #10
lionssfan
lionssfan's Avatar
cool thanks, katech is top notch too. I'm getting heads cnc their
2010
Edit Signature
Old 01-17-2019, 05:34 PM   #11
lionssfan
lionssfan's Avatar
E
EOIT?
2010
Edit Signature
Old 01-17-2019, 06:42 PM   #12
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
EOIT (injector offset timing) has to do with injection timing. With more of a cam, more timing is added (for idle and low rpm). This really affects the stinky. I had to add (retard) 50* timing with my stage 3 cam. Has to do with exhaust valve opening and injector squirting. Retarding that timing will give you less stinky. There are some Excel calculators out there to enter the cam values and it provide what timing needs to be added to fix (most) of it.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 01-17-2019, 07:20 PM   #13
AGP Turbo
Drives: All things Turbocharged
End of injection timing is going to change it so little. That's just how it's going to be. That is the design of that type of cam to get a super fresh charge each cycle. #racecar #loud&smelly
put cats on it or build a turbo car if you want to have class next time I'll be right over------->........ j/k
AGP Turbo is offline   Reply With Quote
Old 01-17-2019, 09:18 PM   #14
realcanuk
realcanuk's Avatar
Have to disagree. Tuning EOIT greatly reduced the smell in my car, not to mention it starts and runs better after.
The excessive smell comes from injecting fuel with the exhaust valve open.
