Old 01-28-2019, 11:12 PM   #1
Leo72793
Drives: 2011 2SS/RS
Installed Lowering springs
With lowering springs, if one strut bolt is a few threads further through the top mount than the other, would that cause issues with driving straight even though the alignment is all within proper spec?
The driver side has 2-4 more threads through the top nut in the mount than the passenger. My car pulls to the right even though its got fantastic alignment.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 01-29-2019, 06:24 AM   #2
Gordy87
Gordy87's Avatar
Drives: 2010 Camaro SS
Did you have an alignment done after installing the springs? Anytime you break the bolts loose and move things around, it is recommened you have one done. I attempted getting my bolts back in the exact spot they were after changing mine, and even though it didnt pull noticeably, the alignment was still off and wore the tires. It will also depend on what drop you went with. The caster and camber are more then likely off. Dont think the bolt being run in more is the true problem.
Gordy87 is offline   Reply With Quote
Old 01-29-2019, 01:49 PM   #3
BMR Sales
BMR Sales's Avatar
Drives: Race Car
are you talking about this gap? it's normal but it should be close side to side
Old 01-29-2019, 04:36 PM   #4
Leo72793
Drives: 2011 2SS/RS
I did. its very within spec.
Old 01-29-2019, 04:37 PM   #5
Leo72793
Drives: 2011 2SS/RS
no not that. The actual nut that tightens that mount down
Old 01-29-2019, 11:40 PM   #6
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
Did you re-clock your bushings. Not sure would matter with the nuts but probably the ride if not done.
https://www.camaro5.com/forums/showthread.php?t=153188
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 01-30-2019, 06:14 PM   #7
Leo72793
Drives: 2011 2SS/RS
NO i didnt. I talked with my alignment guy and were going to follow the above guide. lift it up, loosed front and bounce it with us pushing down, then tighten them and do the front. gunna be a fun 7am xD
Old 01-30-2019, 08:57 PM   #8
Gordy87
Gordy87's Avatar
Oh ok. Looks luke you have a plan already, but one thing I remembered with mine, even after I had my alignment done, was that the sway bar had loosened up on the driver side. May be worth double and tripke checking all the bolts and nuts while in there. Best of luck.
Old 01-30-2019, 09:41 PM   #9
Leo72793
Drives: 2011 2SS/RS
Will do. Thanks!
Old 02-02-2019, 09:59 PM   #10
Tajefe Couple
I've heard instead of trying to bounce the car on a rack or stands some leave things loose and take a lap around the parking lot then pull on the rack and tighten.
Curious if you got things worked out?
Old Skool
Old 02-05-2019, 12:12 PM   #11
Leo72793
Drives: 2011 2SS/RS
Had the entire suspension loosened and adjusted. Says the rears have to be at the camber in the photo
EDIT: Car is straight when driving BUT the steering wheel is off to the right, if i cente rit i go left.
Old 02-05-2019, 10:15 PM   #12
Leo72793
Drives: 2011 2SS/RS
Figured my heights per corner
Driver Front: 28 3/4" ground to fender
Pass Front: 28 3/8" To fender
Driver Rear: 28 3/4" To fender
Pass Rear: 28 ~3/4"
Seems the pass front is almost a half inch too high
Old 02-06-2019, 12:51 AM   #13
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Pass Rear: 28 ~3/4"
Looks like 3/8” low unless you meant driver front. My passenger from stock or with Hotchkis springs was 1/8” higher
VR Baron is offline   Reply With Quote
Old 02-06-2019, 05:18 PM   #14
Leo72793
Drives: 2011 2SS/RS
One of the nuts retaining the front strut is not as far through the top nut. going to level them then recheck height
