Old 01-30-2019, 09:13 PM   #1
oldman14ss
Drives: 2014 1ss camaro
opinions on trunion upgrade
bronze bushings or needle bearings. long haul cross country driver. the Harleys I've rode cross country to Sturgis jamming across south Dakota in hot august days with air cooled engine and bronze bushings no problems. the ls motor oil cooled, lower engine temps. will they have superior longevity as compared to the captive needle bearings? opinions of both sides would be appreciated. the oldman............
oldman14ss is offline   Reply With Quote
Old 01-30-2019, 09:28 PM   #2
John_C
LSx FTW!!!
Drives: 2010 Camaro 2SS RS
I did these and you can get them with CHE bushing if you want...
Texas Speed & Performance 1.72:1 Ratio LS3 Steel Roller Rocker Arm Set w/ Roller Tip #25-TSP172RR-LS3
https://www.texas-speed.com/p-6147-t...oller-tip.aspx
I have over 20,000 miles on them now.
John_C is offline   Reply With Quote
Old 01-30-2019, 09:36 PM   #3
GRNFLSH
GRNFLSH's Avatar
Drives: 2015 Camaro 2SS Green Flash Edition
I’ve put about 14K miles on Straub solid trunions with no issues. After helping a friend fish stock needle bearing out of the oil pan, we replaced his stock rocker bearings to CHE solid trunions. I was impressed with the quality of CHE.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo
GPI VVT SS1 cam and CNC ported heads milled .30
BTR .660 springs, Straub solid bushing trunions
GPI rod-mod intake with I-M heat sheild
Circle D 258mm Pro single disc 3700 rpm stall converter
169F thermostat & manual fan switch
Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft
GRNFLSH is offline   Reply With Quote
Old 01-31-2019, 12:00 AM   #4
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
or save your self a couple of $$ and use these...https://www.ebay.com/itm/Chevy-GM-LS...LEQo:rk:1:pf:0
daily driving on these for over 2 years now.
peace
Old 01-31-2019, 02:46 AM   #5
Bo White
Bo White's Avatar
I didnt want to replace needle bearings with needle bearings.
Old 01-31-2019, 03:34 AM   #6
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
CHE!!! notice my valve train was alittle quiter too. cheap insurance If something lets go, no needle bearings scattered thru you engine.
2012 zl1 stock 7000 miles
2010
TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems.
Edit Signature
lionssfan is offline   Reply With Quote
Old 01-31-2019, 07:49 AM   #7
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
I have the smith brothers kit from GPI (buy the $15 install kit and you will need a small press)
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 01-31-2019, 08:42 AM   #8
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
CHE Bronze without a doubt. Only need a 6" C-clamp to disassemble stockers. CHE assemble by hand with snap ring pliers. No press necessary.
Cheers,
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 01-31-2019, 08:45 AM   #9
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Interesting read. See section Bushings vs Needle Bearings. Almost makes a case for high pressure pump too when using Bushings “in most applications, where the loads and speeds are extremely high, the Jesel stance is the needle-bearing roller is a must. Unlike a rod or main bearing, there is not enough oil pressure available to a lifter roller to sustain an oil film needed between an axle and bushing to keep it from galling or wearing.”
https://www.jbspowercentre.com/wps/w...ydraliclifters
camguynj is offline   Reply With Quote
Old 01-31-2019, 10:43 AM   #10
hammdo
'It's an experiment'
hammdo's Avatar
I have the C.H.E.’s. Did them myself:
https://www.camaro5.com/forums/showp...postcount=1457
-Don
747 RWHP 794 RWTQ
Old 01-31-2019, 10:58 AM   #11
johnnyb305mia
Drives: 2015 Camaro SS 1LE
I personally have ZPP Trunion Upgrade in my car. They have 24k on them no issues for now. ARP rocker arm bolts as well. This is a needle bearing upgrade. Much better configuration than oem, but when I build my motor, I will more than likely go to a solid bushing upgrade.
johnnyb305mia is offline   Reply With Quote
Old 01-31-2019, 02:41 PM   #12
racesloth
Dan
The way the CHE Bronze bushing is designed it retains oil.
Dan
2010 IOM SS
Old 01-31-2019, 04:13 PM   #13
Mamba2010SS
Drives: 2010 camaro ss
I used Straub kit also, no complaints, easy to swap in, i spent the extra 30 and bought the tool to press them in/out pn (228-1213469) which made it go faster
2010 Camaro SS M6 my new found headache
Mamba2010SS is offline   Reply With Quote
Old 02-01-2019, 10:46 AM   #14
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
I have the powell solid bushings that Frank linked. Not a ton of miles on them, but so far so good!! Hard to beat them for the price
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
