Old 01-30-2019, 11:45 PM   #1
SSVictor
Drives: 2010 Camaro 2SS
Overheating
I just got TSP 1-7/8 headers installed two days ago and I’m currently waiting on my tune. I was idling at a drive thru and it said Engine Overheating turning off a/c. Are my headers causing this?
SSVictor is offline   Reply With Quote
Old 01-31-2019, 12:35 AM   #2
Dylan1214
Dylan1214's Avatar
Drives: 2014 Camaro SS L99
I've never heard of that before, Have you checked your coolant level?
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
Dylan1214 is offline   Reply With Quote
Old 01-31-2019, 03:32 AM   #3
SSVictor
I checked the coolant level and it was full
Old 01-31-2019, 04:08 AM   #4
fhrex
Drives: 2011 Camaro 2LT/RS
check for DTCs. Something as simple as low engine temp can trip a code and give the same message
fhrex is offline   Reply With Quote
Old 01-31-2019, 08:20 AM   #5
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Maybe you messed up the temp sensor during the install
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 01-31-2019, 09:10 AM   #6
Juiced1
Drives: 2012 2SS CAMARO 45th
It could be a few things. You could have a bubble in your cooling system but if you didn't refill it lately that is unlikely. I would guess your thermostat got stuck and didn't open. Sometimes a couple quick revs will pop it open and solve the issue. I would check your temp sensor too, it's right next to the headers and may have been damaged during the install.
Juiced1 is offline   Reply With Quote
headers, overheating
