Old 02-01-2019, 09:19 AM   #1
CamaroEMC
Drives: 2010 Camaro 2SS/RS
Chirping Noise
So this morning as I was doing my normal commute to work, I noticed a "chirping" noise developing in the car. I did a few things to narrow down the possibilities, put car in neutral, changed gear, slowed down, etc. The noise seems to be RPM dependent vice speed dependent, and goes away if I put even the slightest amount of pressure on the clutch pedal. Like, I am talking about just enough pressure to take up the slack on the pedal and not enough to start actuating the clutch.
I have seen some posts around here referencing possibly a bushing in the pedal itself, and I will check that out when I get home today. Really, I just want to know other places to look, as I don't want to ignore the possibility that there is something wrong in my clutch system.
Car is a 2010 Camaro 2SS/RS M6 with a cam build.
Thanks,
Keith
2010 Camaro 2SS/RS
BMR Subframe connectors
BMR front and rear swaybars
BMR SPrings with Koni V2 shocks
TSP Cam build tuned to 482 rwhp
CamaroEMC is offline   Reply With Quote
Old 02-10-2019, 06:47 PM   #2
CamaroEMC
Well, thanks for the overwhelming number of responses. Seems to be a throwout bearing. Looks like a new clutch and such is in my future.
2010 Camaro 2SS/RS
