02-03-2019, 03:08 PM | #1 |
Drives: 2017 Silver SS Join Date: Dec 2017
Creaking/popping noise while setting on jack stands
Hey everyone, was wondering if it’s normal for the car to make noise while setting on jack stands. I’m lifting the rear of the car from the crossmember behind the diff, and setting the jackstands on the pinch welds with a small cloth in between. As I lowered the car on the stands I heard a lot of metallic creaking and popping, I immediately lifted and removed the jackstands but found no damage.
Is this okay? I’m trying to install the bmr lockout kit so I can’t use the cradle brace next to the pinch welds. Any help is appreciated! |
02-03-2019, 03:39 PM | #2 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Get yourself a set of these and mount them in the forward opening. https://www.amazon.com/Dewhel-Billet...ro+lift+points
02-03-2019, 03:48 PM | #3 |
Are those safe to use with jack stands? But yeah if it doesn’t make that noise when using the pads that might be the way to go, it just seems like it touches the pinch welds but still lowers an inch or so while creaking and popping, I’m wondering if the crossmember isn’t all the way solid
02-03-2019, 04:59 PM | #4 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 You only need to install the lift pads on the front if you are jacking the rear up from the cross member. This is what I do and I have two lift pads that I never installed. I use two floor jacks to bring the front up semi-evenly first, place the jack stands in the front with the pinch weld adapters, then lift the rear by the cross member (single jack) and place the two rear jack stands with pinch weld adapters.
02-03-2019, 05:26 PM | #5 |
That looks like it would work perfect for my stands
Thanks for the heads up! |
02-04-2019, 10:26 PM | #6 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
Lift Pads
I had mine on jack stands this weekend using the jack pads. The black adapters on top of the stands help with protection.
02-05-2019, 06:48 AM | #7 |
Drives: 2018 2ss 1le Join Date: Jan 2018
those are the same jack stand protectors I use …
love them got them at harbor frieght
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned |
02-05-2019, 08:30 AM | #8 |
So I was able to get the job done without those, I believe the noise I was hearing was the cradle bushings settling
02-05-2019, 09:48 AM | #9 | |
Who Needs to KNOW?
Drives: 18 ZLE Join Date: May 2018
Yup.. looks like someone knocked off ZA jack pads.
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs. http://www.motorsportsne.com/ |
02-05-2019, 10:21 AM | #10 |
Drives: 2000 GMPPSV SS & 2017 ILE SS Join Date: Jul 2017
Imagine the load in your pants if it made that sound while under the car!
