Old 02-05-2019, 09:30 PM   #1
Lawlow97
Drives: Black 2015 camaro 2ss
ZL1 Bumper on 5th gen SS
I am looking to buy a new bumper for my 2015 Camaro 2SS, I was wondering if anyone on here has put on a zl1 bumper onto a 2015 2ss, if so could you let me know where you got it, and if it all lines up perfect thanks
Lawlow97 is offline   Reply With Quote
Old 02-06-2019, 07:25 AM   #2
STALKER
STALKER's Avatar
Drives: 2023 Camaro ZL1 1LE
5th Gen ZL1 bumper, yes. Will an OEM 6th Gen ZL1 bumper bolt on a 5th Gen and line up?...No.
I think there are a couple companies that make aftermarket kits though.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler
2023 Camaro ZL1 / 1LE
Stock
STALKER is offline   Reply With Quote
Old 02-06-2019, 08:50 AM   #3
12blkgrayRS
12blkgrayRS's Avatar
Drives: 2012 Camaro RS 2LT 6spd man
Chevy actually uses the 5th gen bumper cover on the 14-15 ZL1's so yes. It's still a 5th gen..
12blkgrayRS is offline   Reply With Quote
Old 02-06-2019, 10:23 AM   #4
Spec
Drives: 2010 Camaro 1SS LS3
Didn't have to deal with any issues as for a 10 it's a direct swap. Should be for a 14, 15 too, but I believe you will need a new hood also as the lines will not properly line up. You will need new headlights too.
Spec is offline   Reply With Quote
2015 camaro 2ss, 5th gen ss, conversion, zl1 bumper
